5 Replies Latest reply on Apr 24, 2017 3:59 AM by tpk1982
    Change Internal References
    Ananth@desgin Level 3
      Hi All,
      I have work with custom books. I want to change custom books chapter numbers and update the internal references such as figure, table, Map, Lab.
      Example i take chapter 5 to change the chapter 1 and  internal references
      Before                                   After
      Figure 5.1                            Figure 1.1
      Figure 5.2                            Figure 1.2
      Figure 5.15                        Figure 1.15
      how can i do this...?
      app.findGrepPreferences = app.changeGrepPreferences = null;
      app.findGrepPreferences.findWhat = "[A-z]+"
      var Found = app.activeDocument.findGrep();
      for(i=0; i<Found.length; i++)
          if((Found.contents = "FIGURE")&&(Found.contents = "Figure")&&(Found.contents = "figure")&&(Found.contents = "Fig")&&(Found.contents = "fig"))
              //Found[i].fillColor = "Red";
        • 1. Re: Change Internal References
          jakec88782761 Level 2
          Hi Ananth,
          You'd probably be better off making a GREP for each change you want to make.
          At the moment your if statement will only be true if the content of the GREP matches all of your strings.
          If you want to match any of them, use the or operator, like so:
          if((Found.contents = "FIGURE")||(Found.contents = "Figure")||(Found.contents = "figure")||(Found.contents = "Fig")||(Found.contents = "fig"))
          Jake
          • 2. Re: Change Internal References
            Just a quick go at a possible GREP expression:
            ([Ff]ig(ure)?)
            That will find all of the strings in your example, except for the all caps version.
            • 3. Re: Change Internal References
              thanks for your reply jack!!!
              thanks,
              prabu
              • 4. Re: Change Internal References
                Hi
                i have to work user Interface and give the input:
                old chapter: 1
                New chapter: 5
                it will be change the internal reference and change the year(Ex: 1955 inside the para) and number list. how to presreve this?
                if(app.documents.length == 0)
                    alert("Hi User!! Please open the Document")
                    exit();
                var myDoc = app.documents[0];
                var window = new Window ("dialog", "Change Cross-References");
                window.orientation = "row";
                window.preferredSize.width = 100;
                window.preferredSize.height = 100;
                window.location = [500, 400];
                window.add ("statictext", undefined, "Old_Chapter:");
                var find_ref = window.add ("edittext", undefined, "");
                window.graphics.backgroundColor = window.graphics.newBrush (window.graphics.BrushType.SOLID_COLOR, [0, 0.5, 0.5, 0.5]);
                find_ref.characters = 30;
                window.orientation = "column";
                window.add ("statictext", undefined, "New_Chapter:");
                var change_Ref = window.add ("edittext", undefined, "");
                change_Ref.characters = 30;
                var myButtonGroup = window.add ("group");
                myButtonGroup.alignment = "right";
                var Ok =myButtonGroup.add ("button", undefined, "OK");
                var Cancel = myButtonGroup.add ("button", undefined, "Cancel");
                var myResult = window.show();
                //~ if(Cancel.onclick ==1)
                //~     alert("Hi User!! Please Enter the values")
                //~     exit()
                var old_Ref = find_ref.text;
                var new_Ref = change_Ref.text;
                app.findTextPreferences = app.changeTextPreferences  = null;
                app.findTextPreferences.findWhat = old_Ref;
                var found = app.documents[0].findText();
                for(i=0; i<found.length; i++)
                    app.findChangeTextOptions.caseSensitive = false;
                    app.findChangeTextOptions.wholeWord = false;
                    app.changeTextPreferences.changeTo = new_Ref;
                    var myChanges = app.documents[0].changeText();
                if(found.length==0)
                    alert("Hi User!! no text found")
                    exit()
                thanks,
                Prabu
                • 5. Re: Change Internal References
                  tpk1982 Level 4
                  If your chapter number have any paragraph style then use .appliedParagraphStyle in find preference
