2 Replies Latest reply on Apr 24, 2017 3:43 AM by mariannal21350910
    Remove Brush Wet Edges
    mariannal21350910
      Hi guys,
      Please, let me know how to remove Wet edges in the Brush panel, when it's gray and locked. Thanks!
        • 1. Re: Remove Brush Wet Edges
          davidc1815 Level 4
          I don't think you can.  But if it's not active why does it bother you?
          If you are troubled by the apparent watercolour wash effect you get when you overlap brushstrokes this is a function of the Opacity setting.  You need to set Opacity to 100% to stop the overlapped stroke transparency.  The Wet Edges feature will not get rid of the transparent, wash look.  It adds the dried pigment edge look you get with transparent watercolour paint washes, where the sediment dries at the edge of the paint.  Wet Edges, and reduced Opacity, and a Spatter Brush tip make for a nice watercolour look.
          David
          • 2. Re: Remove Brush Wet Edges
            mariannal21350910 Level 1
            Gosh! I had Dissolve Brush mode - my mistake.
            Thanks David!
