15 Replies Latest reply on Apr 28, 2017 10:59 AM by mikevine1
    Find/Change Prices Script from List
    mikevine1
      Can someone help me create a script that would change existing pricing to new pricing within an InDesign document?
      Example:
      Change $2.99 price text to $4.50 price text. (all occurrences in a document).
      The script would access data in an Excel document containing existing prices and the new replacement prices to change in an InDesign document.
      Is something like this possible?
      Thanks for any help or ideas.
      Mike
        • 1. Re: Find/Change Prices Script from List
          Ananth@desgin Level 2
          Mike,
          Please change excel document to .txt format and run the below code.
          Prabu
          • 2. Re: Find/Change Prices Script from List
            mikevine1 Level 1
            Prabu,
            I don't see any excel document or code attached.
            Mike
            • 3. Re: Find/Change Prices Script from List
              Mike,
              Change your excel document to txt format.
              Array.prototype.unique = function() {
                      var res = [], k, i, loop;
                      loop: for (k = 0; k < this.length; k++) {
                                  for (i = 0; i < res.length; i++)
                                      if (this[k] == res[i]) continue loop;
                                  res.push(this[k]);
                      return res;
                  var
                      myDoc =app.documents[0],
                      myFile = File.openDialog("Select a TXT file to proceed","*.txt",false),
                      mySource = [], cLine, cCol1, cCol2;
                  if (!myFile) exit();
                  app.findTextPreferences = app.changeTextPreferences = null;
                  with (app.findChangeTextOptions){
                      includeLockedLayersForFind = true;
                      includeLockedStoriesForFind = true;
                      includeHiddenLayers = false;
                      includeMasterPages = true;
                      includeFootnotes = true;
                      caseSensitive = false;
                      wholeWord = true;
                  myFile.open('r');
                  do
                      mySource.push(myFile.readln());
                      while (!myFile.eof);
                  myFile.close();
                  mySource = mySource.unique();
                  while (cLine = mySource.pop()) {
                      cCol1 = cLine.split("\t")[0];
                      cCol2 = cLine.split("\t")[1];
                      app.findTextPreferences.findWhat = cCol1;
                      app.changeTextPreferences.changeTo = cCol2;
                     var myChanges = myDoc.changeText();
                  alert("Changes Completed")
              • 4. Re: Find/Change Prices Script from List
                mikevine1 Level 1
                Prabu,
                Your script is just what I was looking for, but I have one issue:
                I will be running your script on multiple InDesign documents at a time. I used a script called batch_convert.jsx to execute your script on multiple InDesign documents. When I do this, I receive the message asking for the location of the .txt document each time the script is executed on a InDesign document. This makes sense to me because your script keeps looping that code each time it is run. Is there code that will only ask one time for the .txt document list location?
                Thanks, Mike
                • 5. Re: Find/Change Prices Script from List
                  tpk1982 Level 4
                  Give the path in the variable called myFile..
                  Change
                  To
                          myFile = "~/Desktop/xx.txt" //give your entire path
                  • 6. Re: Find/Change Prices Script from List
                    mikevine1 Level 1
                    tpk1982,
                    I changed:
                    To:
                    myFile = "~/Desktop/TREND US Pricing List_MikeTest4-24.txt" //give your entire path
                    And it didn't change any of the prices. I also received this error after the script ran:
                    Any ideas?
                    • 7. Re: Find/Change Prices Script from List
                      tpk1982 Level 4
                      Are you using Ananth@desgin provided script? Because it have only 45 lines.. but your screenshot shows error in line 79..
                      If you are suing some other code please post here.. so we may know where we missed..Because it clearly shows cLine variable is undefined
                      • 8. Re: Find/Change Prices Script from List
                        mikevine1 Level 1
                        Yes I'm using Ananth@design script with your edit made to it. But I'm using it in conjunction with batch_convert script to batch process multiple InDesign documents. Here is a screen cap:
                        I ran the edited script without using batch_convert script on one open InDesign document and received this error:
                        Ananth@design original script works with batch_convert script, but I have to navigate to the "price list.txt" file each time a InDesign document is opened by the batch_convert script.
                        Thanks everyone for helping me solve this.
                        Mike
                        • 9. Re: Find/Change Prices Script from List
                          tpk1982 Level 4
                          Great.. Is your txt file format like this?
                          old price tab new price
                          • 10. Re: Find/Change Prices Script from List
                            mikevine1 Level 1
                            Yes.
                            The original price list is an excel document. Then Ananth@design told me to save that document to a tab-delimited.txt file.
                            • 11. Re: Find/Change Prices Script from List
                              tpk1982 Level 4
                              We can use csv format.. it we have included , instead of \t..like below
                              cCol1 = cLine.split(",")[0];
                              I hope you are using Peter's batch convert script..
                              If you show how you included Anand script with peter script?
                              Then we are close to the solution
                              • 12. Re: Find/Change Prices Script from List
                                mikevine1 Level 1
                                Within InDesign, I double-click Peter Kahrel batch_convert script and enter the following options in the dialog box below and click OK:
                                Ananth@desgin script then changes all the prices (based on the tab-delimited txt file) to the documents in the Input folder and copies the updated price change documents to the Output folder.
                                • 13. Re: Find/Change Prices Script from List
                                  tpk1982 Level 4
                                  Just copy and paste this as you script.. let see..
                                                      res.push(this[k]);
                                          return res;
                                      var
                                          myFile = "~/Desktop/TREND US Pricing List_MikeTest4-24.txt" ,
                                          wholeWord = true;
                                      myFile.open('r');
                                      do
                                      myFile.close();
                                  • 14. Re: Find/Change Prices Script from List
                                    mikevine1 Level 1
                                    Tried your updated script and still doesn't change the prices and received this error message after script was ran:
                                    • 15. Re: Find/Change Prices Script from List
                                      mikevine1 Level 1
                                      Ananth@desgin,
                                      I ran your script with a 2 row .txt document, and it works great. When I use the actual list I will be using to change prices on multiple InDesign documents, the changing of prices is incorrect. Example:
                                      $14.99 should change to $24.99, but changes to $36.99
                                      $6.99 should change to $11.99, but changes to $19.99
                                      What is weird is those column pairs don't even exist in my .txt files. It seems to randomly change prices to whatever price.
                                      I've attached two .txt files I'm using for my testing. Any ideas what may be happening?
                                      SMALL LIST:
                                      $14.99$24.99
                                      $6.99$11.99
                                      BIG LIST:
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $2.29$4.50
                                      $24.99$36.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $18.99$29.99
                                      $18.99$29.99
                                      $18.99$29.99
                                      $18.99$29.99
                                      $18.99$29.99
                                      $18.99$29.99
                                      $18.99$29.99
                                      $18.99$29.99
                                      $18.99$29.99
                                      $18.99$29.99
                                      $18.99$29.99
                                      $18.99$29.99
                                      $18.99$29.99
                                      $18.99$29.99
                                      $18.99$29.99
                                      $18.99$29.99
                                      $18.99$29.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $59.95$89.99
                                      $59.95$89.99
                                      $64.95$99.99
                                      $64.95$99.99
                                      $64.95$99.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $11.99$19.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $8.49$13.99
                                      $8.49$13.99
                                      $8.49$13.99
                                      $8.49$13.99
                                      $8.49$13.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $4.59$7.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $3.69$6.99
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $2.99$4.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $4.99$8.99
                                      $5.99$9.99
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $11.49$19.99
                                      $11.49$19.99
                                      $11.49$19.99
                                      $11.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $21.99$34.99
                                      $21.99$34.99
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $12.49$19.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $17.49$27.99
                                      $17.49$27.99
                                      $17.49$27.99
                                      $17.49$27.99
                                      $17.49$27.99
                                      $7.99$13.50
                                      $7.99$13.50
                                      $9.99$15.99
                                      $9.99$15.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $10.99$16.99
                                      $21.99$34.99
                                      $39.99$59.99
                                      $19.99$32.99
                                      $19.99$32.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $3.29$6.99
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $4.29$7.50
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $8.49$13.99
                                      $11.49$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $1.79$3.50
                                      $1.99$3.50
                                      $7.29$12.50
                                      $7.29$12.50
                                      $7.29$12.50
                                      $7.29$12.50
                                      $7.29$12.50
                                      $7.29$12.50
                                      $7.29$12.50
                                      $7.29$12.50
                                      $7.29$12.50
                                      $7.29$12.50
                                      $7.29$12.50
                                      $7.29$12.50
                                      $7.29$12.50
                                      $7.29$12.50
                                      $7.29$12.50
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $6.29$9.99
                                      $6.29$9.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $7.29$12.50
                                      $7.29$12.50
                                      $7.49$12.50
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $4.49$7.50
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.49$8.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $8.49$13.99
                                      $8.49$13.99
                                      $8.49$13.99
                                      $8.49$13.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $24.99$36.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $8.99$14.99
                                      $8.99$14.99
                                      $8.99$14.99
                                      $8.99$14.99
                                      $8.99$14.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $9.99$15.99
                                      $13.99$22.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $6.99$11.99
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $7.99$13.50
                                      $8.99$14.99
                                      $8.99$14.99
                                      $8.99$14.99
                                      $8.99$14.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $1.99$3.50
                                      $24.99$36.99
                                      $8.99$14.99
                                      $8.99$14.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $12.99$19.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $5.99$9.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $32.49$49.99
                                      $33.49$49.99
                                      $33.99$49.99
                                      $34.99$52.99
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.59$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $8.49$13.99
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $24.99$36.99
                                      $7.49$12.50
                                      $7.49$12.50
                                      $14.99$24.99
                                      $8.49$13.99
                                      $8.49$13.99
                                      $8.49$13.99
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $2.59$4.75
                                      $2.49$4.75
                                      $2.49$4.75
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $7.49$12.50
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $6.99$11.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $2.99$4.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $2.99$4.99
                                      $13.99$22.99
                                      $13.99$22.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $14.99$24.99
                                      $15.99$25.99
                                      $15.99$25.99
                                      $15.99$25.99
                                      $15.99$25.99
                                      $15.99$25.99
                                      $20.49$32.99
                                      $20.99$32.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $11.99$19.99
                                      $15.99$25.99
                                      $15.99$25.99
                                      $15.99$25.99
                                      $15.99$25.99
                                      $19.99$32.99
                                      $9.99$15.99
                                      $9.99$15.99
                                      $7.99$13.50
                                      $7.99$13.50
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $4.99$8.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.49$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $3.99$6.99
                                      $19.99$32.99
                                      $19.99$32.99
                                      $19.99$32.99
                                      $19.99$32.99
                                      $19.99$32.99
                                      $3.29$6.99
                                      $4.49$7.50
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $5.99$9.99
                                      $6.49$10.99
                                      $6.49$10.99
                                      $3.99$6.99
                                      $4.49$7.50
                                      $5.99$9.99
                                      $6.99$11.99
