Is there any way using ExtendScript to control the property values of Motion Graphics clips instances in the timeline? (by "Motion Graphics" I'm referring to the Motion Graphics / Essential Graphics feature introduced in PPro 2017.1)
Looking to develop the following workflow:
- Editor drops a Motion Graphics clip into the timeline.
- Assigns an instance name to the clip in the timeline (via Timeline Click > Rename)
- ExtendScript uses the instance name to control any properties in the Motion Graphics Effects -- text, slider controls, etc
Try /PProPanel/payloads/from_ae.mogrt.
Did you find a way to do this ?
Does this not work for you?
https://github.com/Adobe-CEP/Samples/blob/5adff5bfad64ed20ae68770ab0e2401790d47e7e/PProPanel/jsx/PPRO/Premiere.jsx#L1792
I can import mogrt, but I cant change text inside....
variable "moComp" returns null...
can you send me sample mgt file which will work with your code??
osx 10.15.5
ppro 14.3.0
Thank you!!
After editing your mogrt I successfully update text from extend script!!
Do you have any idea how to update duration of track item imported from mogrt?
Sadly, not possible today; we're tracking that work as DVAPR-4212165.
