2 Replies Latest reply on Apr 24, 2017 11:10 PM by carlosp66938218
    Error to build my app and the log doesn't help me
    carlosp66938218 Level 1
      Hi guys.
      I've got an error every time a build my app (1455286) but the log file seems broken and I don't know why my app can be built.
      Build Date: 2017-04-24 11:09:36 +0000
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-camera" via npm
      Installing "cordova-plugin-camera" at "2.4.0" for android
      Fetching plugin "cordova-plugin-compat" via npm
      Installing "cordova-plugin-compat" at "1.1.0" for android
      Subproject Path: CordovaLib
      Fetching plugin "cordova-plugin-console" via npm
      Installing "cordova-plugin-console" at "1.0.6" for android
      Fetching plugin "cordova-plugin-device" via npm
      Installing "cordova-plugin-device" at "1.1.5" for android
      Fetching plugin "cordova-plugin-dialogs" via npm
      Installing "cordova-plugin-dialogs" at "1.3.2" for android
      Fetching plugin "cordova-plugin-file-transfer" via npm
      Installing "cordova-plugin-file-transfer" at "1.6.2" for android
      Fetching plugin "cordova-plugin-file" via npm
      Installing "cordova-plugin-file" at "4.3.2" for android
      Dependent plugin "cordova-plugin-compat" already installed on android.
      The Android Persistent storage location now defaults to "Internal". Please check this plugin's README to see if your application needs any changes in its config.xml.
      If this is a new application no changes are required.
      If this is an update to an existing application that did not specify an "AndroidPersistentFileLocation" you may need to add:
        "<preference name="AndroidPersistentFileLocation" value="Compatibility" />"
      to config.xml in order for the application to find previously stored files.
      Fetching plugin "cordova-plugin-network-information" via npm
      Installing "cordova-plugin-network-information" at "1.3.2" for android
      Fetching plugin "cordova-plugin-splashscreen" via npm
      Installing "cordova-plugin-splashscreen" at "4.0.2" for android
      Fetching plugin "cordova-plugin-statusbar" via npm
      Installing "cordova-plugin-statusbar" at "2.2.2" for android
      Fetching plugin "manateeworks-barcodescanner@2.0.0" via npm
      Installing "manateeworks-barcodescanner" at "2.0.0" for android
      Dependent plugin "cordova-plugin-dialogs" already installed on android.
      Dependent plugin "cordova-plugin-device" already installed on android.
      Fetching plugin "cordova-plugin-inappbrowser" via npm
      Installing "cordova-plugin-inappbrowser" at "1.7.0" for android
      Fetching plugin "cordova-plugin-x-socialsharing" via npm
      Installing "cordova-plugin-x-socialsharing" at "5.1.7" for android
      Fetching plugin "onesignal-cordova-plugin" via npm
      Installing "onesignal-cordova-plugin" at "2.0.11" for android
      Fetching plugin "cordova-plugin-whitelist" via npm
      Installing "cordova-plugin-whitelist" at "1.3.2" for android
        This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
      Fetching plugin "cordova-plugin-datepicker" via npm
      Installing "cordova-plugin-datepicker" at "0.9.3" for android
      Fetching plugin "cordova-plugin-appavailability" via npm
      Installing "cordova-plugin-appavailability" at "0.4.2" for android
      Fetching plugin "cordova-plugin-google-analytics" via npm
      Installing "cordova-plugin-google-analytics" at "1.7.11" for android
      Fetching plugin "cordova-plugin-ios-camera-permissions" via npm
      Installing "cordova-plugin-ios-camera-permissions" at "1.1.1" for android
      Can anyone help me?
      Thanks in advance.
      Regards.
