4 Replies Latest reply on Dec 17, 2008 6:57 AM by nickname118
    Accessing styles of a component
    nickname118
      Forgive me if this has an obvious answer, but I am curious. How can I get an object or a list of all styles or CSSStyleDeclaration objects that will be applied to a component?
      Like say for a simple example I have a stylesheet "myStyles.css" in my project. And I set it in my component with the Style tag:
      <mx:Style source="myStyles.css" />
      How can I see inside the component what all the styles are that can be applied in that component?
      Like say I've made class selectors in my stylesheet, and in my app I want to know what styles they might have before I actually apply them to any objects. I'm not sure where the stylesheet lives when you add it this way, so I don't know how to go about finding it.
        • 1. Re: Accessing styles of a component
          Level 7
          "nickname118" <webforumsuser@macromedia.com> wrote in message
          news:ghuese$fe7$1@forums.macromedia.com...
          > an
          > applied
          > in that component?
          > to
          > objects.
          > don't
          Typically the way this is done is by overriding the setStyle function and
          setting a flag when "your" styles come in so that you can change them in
          updateDisplayList.
          HTH;
          Amy
          • 2. Re: Accessing styles of a component
            nickname118 Level 1
            No, meant a list of all available styles.
            For example, there is a property of StyleManager called selectors. This is an Array of all the available class and type selectors.
            But how do I get the actual styles out of that? There is a function StyleManager.getStyleDeclaration() that I can call for each selector in the array, but I don't know of a way to get at the actual styles inside each selector if I don't know them in advance. All the CSSStyleDeclaration class has is a method getStyle(), but it requires you to provide a name of that style. Surely there must be an array, or arrays somewhere that the CSSStyleDeclaration is checking to return the values for you.
            • 3. Re: Accessing styles of a component
              Level 7
              news:ghui7s$jkg$1@forums.macromedia.com...
              > an
              > the
              > class has
              > style.
              > CSSStyleDeclaration
              I'm not sure what it really gets you to try to go around the inbuilt method
              the Flex Engineers created for handling styling. Good luck, though.
              • 4. Re: Accessing styles of a component
                nickname118 Level 1
                I am building two versions of the same component. One in Flex, and the other in html, so that the user can print the content they are viewing.
                I had originally built a print preview page, but it was iffy at best. So we're just going to throw everything into an html page and open that in a new window when the user wants to print.
                I would have liked to keep my flex stylesheet, and use those values to assign to the html styles, but it looks like I need a separate one that I will have to maintain to make sure they match. Oh well.
