8 Replies Latest reply on Apr 25, 2017 7:22 AM by Sue Garibaldi
    Capture not syncing well
    sytsew
      My mobile Capture version seems to be having trouble connecting to the server.
      a) Is there any way to reset or force sync?
      b) is there any way to share shapes in my mobile library i na different way, e.g. sending one through mail? I created (and saved) a trace image and need to process it further elsewhere, and I'm in a hurry...
      taking the standard questions from a recent post:
      On the mobile side:
      1. What hardware platform? Android 6.0 / Huawei EMUI 4.0.1
      2. What OS version? see up
      3. What version of Capture? 2.6.656
      4. Are you signed in to your Adobe ID? yes
      On the desktop side:
      [this is less relevant for my problem as it seems to be mobile-side only]
      1. What hardware platform? OSX
      2. What OS version? 10.12.4
      3. What CC app, and what exact version? Illustrator + Photoshop 2017, latest
      4. Are you signed in to the same Adobe ID? yes
      On the web:
      1. Can you go to assets.adobe.com and sign in to see your Library items? Yes, and I don't see a newly created library (with one test image) appearing.
        • 1. Re: Capture not syncing well
          Sue Garibaldi Adobe Employee (Admin)
          Sytsew.
          Sorry the app's not working correctly. I haven't heard of sync problems in this version of the app but I have had a number of people having trouble with Huawei devices so I'd like to try to figure out what's happening.
          First, though, since you're in a hurry and it sounds like you have a Creative Cloud account there are additional ways to share/save a shape: Tap the shape you want to share. Then, from the upper nav, tap the share icon. From the menu that opens choose Export As. The next menu that opens will give you a number of options for saving the asset.
          After you get your project done, can you check a couple of things for me:
          * When you log in to Adobe Creative Cloud can you see any of your Capture libraries?
          * Check your wifi/data connection; use your mobile browser (on the same device) to navigate to any site that isn't cached.
          * Try forcing a sync in the problem library; swipe/pull down from top to bottom in library that won't sync. Then try logging in to Adobe Creative Cloud to see if your wok has synced.
          * If that doesn't work, try signing out of the app then signing back in.
          Let me know how things are going.
          Sue.
          • 2. Re: Capture not syncing well
            sytsew Level 1
            Small update, while the issue persists, for those in a similar situation: I managed to mail myself a screenshot of the traced image on my mobile, and trace that in Illustrator. That at least takes the urge off
            • 3. Re: Capture not syncing well
              sytsew Level 1
              Hi Sue, thanks for answering, and thanks for the tip how to Export As, I hadn't found that one before.
              In reply to your questions, now I'm done for tonight:
              Online, yes. On phone: no. I tried making a new library folder (with the single image in it) but it has never shown up online in CC so far.
              No, I'm on a eduroam wifi connection inside a university. Will try when home later to see if that's been a factor.
              Tried that already a couple of times: the updating sign just keeps spinning (like a beachball in OSX)
              Will try that one again when home.
              • 4. Re: Capture not syncing well
                Sytsew.
                Thanks for all the details; they're super helpful.
                Let me know what you find when you try a different Internet connection, it could be a firewall causing the problem, and we'll go from there.
                Sue.
                • 5. Re: Capture not syncing well
                  sytsew Level 1
                  Update, now in different network:
                  immediately forcing a server sync did not work, but after signing out, closing the app, restarting and signing in again it seems to work now, and finally online CC libraries are sync'd too. I'll try tomorrow if this normal state persists in my work's network, and let you know.
                  Thanks for the help, Sytse.
                  • 6. Re: Capture not syncing well
                    Sytse.
                    Good. Great. I am curious to know what happens at work...
                    Sue.
                    • 7. Re: Capture not syncing well
                      sytsew Level 1
                      Hi Sue,
                      it seems to work fine at work now, too. So it must've been an account login issue.
                      What happens at work? More work ...
                      Thanks for the help!
                      • 8. Re: Capture not syncing well
                        Glad it's working Sytse.
                        Have a good day.
                        Sue.
