4 Replies Latest reply on Apr 25, 2017 6:31 AM by Peter Kahrel
    parentPage is not working in CS4
    tpk1982 Level 4
      I am using the below script to clear paste board and getting the details what I cleared. But It is not working in CS4. It throw error in line 21, with parenPage is not supporting.
      I tried instance of Spread but no use.
      Original Thread: Re: Pasteboard items information
      Could you please help to solve this?
      var scriptName = "Delete objects on pasteboard",
      doc;
      PreCheck();
      function Main() {
          var obj, howManyImages,
          objs = doc.pageItems.everyItem().getElements(),
          countTotal = countTextFrame = countRectangle = countImage = 0;
          var lnkname=[];
           var layers=doc.layers;
          for(var i=0;i<layers.length;i++){
          if (layers[i].locked){
             layers[i].locked=false;
          var links = doc.links;
          for(var j = 0; j < links.length; j++){
          if(links[j].parent.parent.parentPage == null){
              lnkname.push(links[j].name);
          for (var i = objs.length - 1; i >= 0; i--) {
              obj = objs[i];
              //lnkname.push(doc.allGraphics[i].itemLink.name);
      //var doc = app.activeDocument;
             if(obj.parentPage == null) {
                  if (obj.locked) {
                      obj.locked = false;
                  try {
                      howManyImages = obj.allGraphics.length;
                      obj.remove();
                      countTotal++;
                      countImage += howManyImages;
                  if (obj instanceof TextFrame) {
                          countTextFrame++;
                      if (obj instanceof Rectangle) {
                          countRectangle++;
                  catch(err) {
                      $.writeln(err.message + ", line: " + err.line);
          var report = (countTotal == 0) ? "Nothing has been removed." :
                              "In total " + countTotal + " object" + ((countTotal == 1) ? " was" : "s were") + " removed.\nIncluding:\n\n" +
                              countTextFrame + " Text Frame" + ((countTextFrame == 1) ? "" : "s") + "\n" +
                              Number(countRectangle-countImage) + " Rectangle" + ((countRectangle == 1) ? "" : "s") + "\n" +
                              countImage + " Image" + ((countImage == 1) ? "" : "s" + "\nImage Name - \n"+lnkname.join("\n"));
          alert(report, scriptName);
      function PreCheck() {
          if (app.documents.length == 0) ErrorExit("Please open a document and try again.", true);
          if (doc.converted) ErrorExit("The current document has been modified by being converted from older version of InDesign. Please save the document and try again.", true);
          if (!doc.saved) ErrorExit("The current document has not been saved since it was created. Please save the document and try again.", true);
          Main();
      function ErrorExit(error, icon) {
          alert(error, scriptName, icon);
          exit();
      Regards,
      K
