A designer made a PDF for us using Open Sans font. I can view the PDF fine, but when I try to edit text the font isn't available. I've tried Optimize PDF using Preflight, and Print Production Preflight but neither seem to work ~ 'analyze & fix'. How do i install missing fonts, and how is it possible that Acbrobat DC Pro doesn't have Open Sans pre-installed?
Trevor
Install the font like any other font on your system.
You write " how is it possible that Acbrobat DC Pro doesn't have Open Sans pre-installed" but there are hundreds of thousands of fonts, costing millions of dollars. Clearly Acrobat Pro can't have them all, why do you feel it should have this one?
Thanks Bernd, I'm not a designer and unfamiliar with some of the basics around system fonts v. application fonts ~ or so I thought. Very helpful guidance, for others with same issue:
1. download desired font from Googel - Google Fonts | Google Developers
2. unzip file
3. right click on file > install
Thank you so much Trevor, I am also not a pro and your instructions really helped me, thanks for coming back to share. Some people just assume we should all be experts lol. Thanks again!!
does not give me the option to download - all I want to do is print a form can not life be simple?
