Hello Fellow Musers,
I was hoping someone can help me out here?
I'm working on a Site and have used a Responsive Composition Widget on a Page -
However I want that Said Widget to Stop Affecting that Page on a Larger Breakpoint, This is not possible - by the developer
So I wanted to ask is it possible to Redirect the Users Browser to a New Page without that Said Widget -
but it must be based on the Browser Width...
For Example:
So the Widget appears on a Break point 980px and I would like a Redirect to a New Page to happen
when the Browser is at 1100px (to a page without that Widget - as just hiding the Widget does not work)
I hope this is clear...
Thanks in advance to those that read this and help out - Fingers crossed.
Cheers
Ben
Thank you for your input - I have found a work around. I redesigned the site.
As with widgets if you hide this one it Still Affects them... I had feedback from the devloper
and this is not changeable - so hence i changed my site.
Solved for now.
Thanks again.
Ben
Hi Ben,
I fear that this isn't possible with Muse, and not even with any other application.
However, request other members as well to put their inputs if any.
Regards,
Ankush
I guess, the only way, if the user realizes an error (which error, or why should the widget get hidden in another breakpoint?), to link to another page without this widget.
But why do you just not easily hide this widget in this certain breakpoint 1100px.
This should be quite easy, shouldn`t it?
You could replace your Said widget with any other widget.
If I got it wrong, we need a link and a more precise explanation what you do not want to appear and I`m sure, if there´s a solution, we find it.
Hope this helps
Great Uwe, I guess what you suggested is much convenient and practical way to achieve the OPs objective.
Looks like you got the point.
Cheers,
Ankush
Hi Ankush,
I have good teachers ....
Cheerio
Uwe
Solved for now.
Thanks again.
Ben
