18 Replies Latest reply on Apr 26, 2017 12:30 PM by Roei Tzoref
    clone stamp not sticking...
    jimtron Level 1
      I'm really new to AE; have been watching tutorials and will continue to learn. In the meantime there's something relatively simple I'm trying to do; use the clone stamp to "erase" my tripod from a 360 video shot (don't need motion tracking, it's a static shot). I'm using 360VRToolbox plugin, "reorient sphere" setting to change the equirectangular view to something better for cloning tripod.
      I am able to clone/erase tripod, but when I change the view back to equirectangular, my cloning work gets shifted, so it's no longer in the right place--an entirely different part of the frame is getting cloned. Still learning about layers and comps, maybe it has to do with that?
      Any help would be appreciated, or links to tutorials, etc.
      Attaching screenshots of tripod, erased tripod, and how cloning work gets shifted after reverting back to equirectangular view. Screen Shot 2017-04-25 at 7.36.17 PM.png
        • 1. Re: clone stamp not sticking...
          You have to pre-compose. The cloning works just as it should, but apparently you don't understand how AE's rendering order works. You can't just toggle stuff inside an effect and hope AE somehow will magically know what to do.
          Mylenium
          • 2. Re: clone stamp not sticking...
            jimtron Level 1
            Thanks for the reply; I wasn't expecting magic, as I said I'm new to AE, trying to understand how it works.
            I read about precomposition here, but in this description it's assumed that I have multiple layers in the timeline panel, which I don't have.
            • 3. Re: clone stamp not sticking...
              Roei Tzoref Adobe Community Professional
              Hi jimtron. It Also says this: "Precomposing a single layer is useful for adding transform properties to a layer and influencing the order in which elements of a composition are rendered."
              some render operations require precomposing. Some are obvious, And some you learn by trial and error. This is because Some effects (most) will rasterize the layer after the effect is applied and this allows you to apply multiple effects on the same layer. some won't so you have to precomp to reasterize.
              Precompose the layer with the clone effect and choose "move all attributes". Now apply the second effect To the precomp.
              • 4. Re: clone stamp not sticking...
                jimtron Level 1
                Thanks Roei. I've tried precomposing the layer but still having the issue. The clone works, even with playback. But when I reorient the view to equirectangular via the 360VR plugin, the cloning stays exactly where it was in relation to the frame, instead of staying with the ground area (like in OP screenshots).
                Is there another rendering step I may be missing?
                • 5. Re: clone stamp not sticking...
                  kirkeric Adobe Community Professional
                  I'd just add that if it is a still shot, I'm not even sure I'd use the clone stamp.
                  I'd just copy a section of the grass, place it over the item and feather the edges.  It will probably look less obvious too.
                  Eric
                  • 6. Re: clone stamp not sticking...
                    Show us full screen of the U.I on both comps. Press UU on the layer so we can see all modified properties and keep the effect controls panel open.
                    • 7. Re: clone stamp not sticking...
                      jimtron Level 1
                      Thanks Kirkeric: It is a video clip, but camera locked down...copying a section of grass would work, but the problem I'm having is to get a clear view of tripod I have to reorient equirectangular view--which is no problem--but after erasing tripod, I'm having trouble baking that work in, so when I go back to equi view the retouching is in the wrong place.
                      Again, I'm super new to AE, probably doing something dumb. I've tried rendering and pre-composing.
                      • 8. Re: clone stamp not sticking...
                        Hi Jimtron,
                        Going further on the locked down, still angle - If in fact it is locked down, I'd freeze the image or fix and render a single still, bring it back in and then extend to length.  It would be baked in that way for sure.
                        Eric
                        • 9. Re: clone stamp not sticking...
                          jimtron Level 1
                          Roei: missed post #6 before. I'm attaching screenshots, let me know if there's more you want to see.Screen Shot 2017-04-26 at 11.13.31 AM.pngScreen Shot 2017-04-26 at 11.13.47 AM.png
                          • 10. Re: clone stamp not sticking...
                            jimtron Level 1
                            Eric: I am able to get clone stamp work baked in. But not after reorienting image, which is necessary to get clear view of tripod.
                            • 11. Re: clone stamp not sticking...
                              Jim,
                              Ok.  I'm trying to visualize in my head. So, you are clone stamping the object out and then rendering the length of the video to "lock it down"?  Right?  What kind of reorienting are you doing?  Rotating?
                              In any case, if you are stamping it, locking it down, and adjusting it resulting in it slipping, that tells me there is either movement in the video or the process is creating a movement that is impacting that clone stamp.
                              On the surface, it seems locking it down (aka baking it in), pre-comping should address that.
                              And not to beat a dead horse but it really seems the still would fix all of that.  I promise I won't mention that again though.
                              Eric
                              • 12. Re: clone stamp not sticking...
                                jimtron Level 1
                                Right. I'm using the 360VR Toolbox plugin (reorient sphere specifically) to reorient an equirectangular spherical panorama, to access the nadir. At 1:05 in this video, what I'm doing is shown: 360VR Toolbox Public Beta Launch Video - YouTube
                                The clone work isn't slipping; it's staying where it is, instead of moving back down to the bottom of the frame with the image, when I change the effect back to equi orientation.
                                • 13. Re: clone stamp not sticking...
                                  Jim,
                                  I see it more clear now on your problem.
                                  Have you happened to look at some of Mettle's tutorials?  (The maker of Skybox)
                                  You may have already seen all of these but the top right video may shed light.  Apologies if you have done this already.
                                  http://www.mettle.com/skybox-tutorials/
                                  Eric
                                  • 14. Re: clone stamp not sticking...
                                    I don't see you selected "move all attributes". these are the steps: you flatten your footage, clone stamp it, then precomp "move all attributes", then on that precomp you apply the reverse back with the plugin. try it.
                                    • 15. Re: clone stamp not sticking...
                                      jimtron Level 1
                                      Yes, I've seen that; that's exactly what I'm doing, but with a different plugin. With 360VR Toolbox I'm able to clone the tripod out, but not bake in the cloning when returning to equi view.
                                      • 16. Re: clone stamp not sticking...
                                        That sure sounds like the fix!
                                        • 17. Re: clone stamp not sticking...
                                          jimtron Level 1
                                          That did it! Thanks Roei, checking "move all attributes" and reorienting with the precomp did the trick, thanks for your help.
                                          • 18. Re: clone stamp not sticking...
                                            Glad we got you sorted!
