3 Replies Latest reply on Apr 27, 2017 12:16 AM by tpk1982
    Modification need for AddGuides.jsx
    tpk1982 Level 4
      The AddGuides.jsx is an inbuild script in Indesign. It will open the UI and set as our desired input.
      Is it possible to run this script without UI? I meant I need to add guides with default value in UI.
      Challenges:
      1) I can use app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;  but it only hide the UI
      2) How to disable the onclick function for OK button? So that it will run without asking UI.
      //AddGuides.jsx
      //An InDesign JavaScript
      @@@BUILDINFO@@@ "AddGuides.jsx" 3.0.0.0 14 December 2009
      //This script draws guides around the selected object or objects.
      //Choose Visible Bounds to consider the stroke weight of the paths when placing the guides,
      //or choose Geometric Bounds to ignore the stroke weight when placing the guides
      //Choose Each Item to position the guides around individual items in the selection,
      //or Entire Selection to position the guides around the selection as a whole.
      //This script also includes an alternative dialog box for the script. This dialog was
      //created using the ExtendScript ScriptUI component. ScriptUI lacks some of the useful
      //controls that the InDesign dialog object offers, but it can be used to create interactive
      //dialog boxes and panels.
      //For more information on InDesign scripting, go to http://www.adobe.com/products/indesign/scripting/index.html
      //Or visit the InDesign Scripting User to User forum at http://www.adobeforums.com.
      main();
      function main(){
        //Make certain that user interaction (display of dialogs, etc.) is turned on.
        app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
        var myObjectList = new Array;
        if (app.documents.length != 0){
        if (app.selection.length != 0){
        for(var myCounter = 0;myCounter < app.selection.length; myCounter++){
        switch (app.selection[myCounter].constructor.name){
        case "Rectangle":
        case "Oval":
        case "Polygon":
        case "TextFrame":
        case "Group":
        case "Button":
        case "GraphicLine":
        myObjectList.push(app.selection[myCounter]);
        break;
        if (myObjectList.length != 0){
        var myOldXUnits = app.documents.item(0).viewPreferences.horizontalMeasurementUnits;
        var myOldYUnits = app.documents.item(0).viewPreferences.verticalMeasurementUnits;
        app.documents.item(0).viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
        app.documents.item(0).viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
        myDisplayDialog(myObjectList);
        //Comment out the previous line and uncomment the following line to use a ScriptUI dialog.
        //myDisplayScriptUIDialog(myObjectList);
        app.documents.item(0).viewPreferences.horizontalMeasurementUnits = myOldXUnits;
        app.documents.item(0).viewPreferences.verticalMeasurementUnits = myOldYUnits;
        else{
        alert ("Please select a page item and try again.");
        else{
        alert ("Please select an object and try again.");
        else{
          alert ("Please open a document, select an object, and try again.");
      function myDisplayDialog(myObjectList){
        var myRangeButtons, myBasedOnButtons;
        var myLabelWidth = 100;
        var myDialog = app.dialogs.add({name:"AddGuides"});
        with(myDialog){
        with(dialogColumns.add()){
        with(borderPanels.add()){
        staticTexts.add({staticLabel:"Add Guides At:"});
        var myTopCheckbox = checkboxControls.add({staticLabel:"&Top", checkedState:true});
        var myLeftCheckbox = checkboxControls.add({staticLabel:"&Left", checkedState:true});
        var myBottomCheckbox = checkboxControls.add({staticLabel:"&Bottom", checkedState:true});
        var myRightCheckbox = checkboxControls.add({staticLabel:"&Right", checkedState:true});
        var myXCenterCheckbox = checkboxControls.add({staticLabel:"&Horizontal Center", checkedState:true});
        var myYCenterCheckbox = checkboxControls.add({staticLabel:"&Vertical Center", checkedState:true});
        var myXPointCheckbox = checkboxControls.add({staticLabel:"Path Point Hori&zontal Anchor", checkedState:false});
        var myYPointCheckbox = checkboxControls.add({staticLabel:"Path Point Verti&cal Anchor", checkedState:false});
        staticTexts.add({staticLabel:"Add Guides Around:"});
        with(myRangeButtons = radiobuttonGroups.add()){
        radiobuttonControls.add({staticLabel:"Each &Object", checkedState:true, minWidth:156});
        radiobuttonControls.add({staticLabel:"Entire &Selection"});
        with(dialogRows.add()){
        staticTexts.add({staticLabel:"Guides Based On:"});
        with(myBasedOnButtons = radiobuttonGroups.add()){
        radiobuttonControls.add({staticLabel:"&Geometric Bounds", checkedState:true, minWidth:160});
        radiobuttonControls.add({staticLabel:"V&isible Bounds"});
        staticTexts.add({staticLabel:"Horizontal Offset:", minWidth:myLabelWidth});
        var myXOffsetField = measurementEditboxes.add({editValue:0, editUnits:MeasurementUnits.points});
        staticTexts.add({staticLabel:"Vertical Offset:", minWidth:myLabelWidth});
        var myYOffsetField = measurementEditboxes.add({editValue:0, editUnits:MeasurementUnits.points});
        myReturn = myDialog.show();
        if (myReturn == true){
        //Get control values from the dialog box.
        var myTop = myTopCheckbox.checkedState;
        var myLeft = myLeftCheckbox.checkedState;
        var myBottom = myBottomCheckbox.checkedState;
        var myRight = myRightCheckbox.checkedState;
        var myXCenter = myXCenterCheckbox.checkedState;
        var myYCenter = myYCenterCheckbox.checkedState;
        var myXPoint = myXPointCheckbox.checkedState;
        var myYPoint = myYPointCheckbox.checkedState;
        var myBasedOn = myBasedOnButtons.selectedButton;
        var myRange = myRangeButtons.selectedButton;
        var myXOffset = myXOffsetField.editValue;
        var myYOffset = myYOffsetField.editValue;
        //Remove the dialog box from memory.
        myDialog.destroy();
        if(myTop+myLeft+myBottom+myRight+myXCenter+myYCenter+myXPoint+myYPoint !=0){
        myAddGuides(myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myRange, myBasedOn, myXOffset, myYOffset, myXPoint, myYPoint, myObjectList);
        else{
        alert("No guides were specified.");
        else{
        myDialog.destroy();
      //ScriptUI version of the above dialog box.
      function myDisplayScriptUIDialog(myObjectList){
        var myBasedOn, myRange;
        var myDialog = new Window('dialog', 'AddGuides');
        with(myDialog){
        alignChildren = 'fill';
        var myGuideTypesPanel = add('panel', undefined, "Add Guides At:");
        with(myGuideTypesPanel){
        orientation = 'column';
        alignChildren = 'left';
        margins = [12, 16, 12, 6];
        spacing = 4;
        myDialog.myTopCheckbox = add('checkbox', undefined, "Top");
        myDialog.myTopCheckbox.value = true;
        myDialog.myLeftCheckbox = add('checkbox', undefined, "Left");
        myDialog.myLeftCheckbox.value = true;
        myDialog.myBottomCheckbox = add('checkbox', undefined, "Bottom");
        myDialog.myBottomCheckbox.value = true;
        myDialog.myRightCheckbox = add('checkbox', undefined, "Right");
        myDialog.myRightCheckbox.value = true;
        myDialog.myXCenterCheckbox = add('checkbox', undefined, "Horizontal Center");
        myDialog.myXCenterCheckbox.value = true;
        myDialog.myYCenterCheckbox = add('checkbox', undefined, "Vertical Center");
        myDialog.myYCenterCheckbox.value = true;
        myDialog.myXPointCheckbox = add('checkbox', undefined, "Path Point Horizontal Anchor");
        myDialog.myXPointCheckbox.value = true;
        myDialog.myYPointCheckbox = add('checkbox', undefined, "Path Point Vertical Anchor");
        myDialog.myYPointCheckbox.value = true;
        var myGuideLocationPanel = add('panel', undefined, "Add Guides Around:");
        with(myGuideLocationPanel){
        margins = [12, 14, 12, 6];
        spacing = 4;
        myDialog.myEachObjectRadioButton = add('radiobutton', undefined, "Each Object");
        myDialog.myEachObjectRadioButton.value = true;
        myDialog.myEntireSelectionRadioButton = add('radiobutton', undefined, "Entire Selection");
        var myGuidesBasedOnPanel = add('panel', undefined, "Add Guides Based On:");
        with(myGuidesBasedOnPanel){
        spacing = 4;
        myDialog.myGeometricBoundsRadioButton = add('radiobutton', undefined, "Geometric Bounds");
        myDialog.myGeometricBoundsRadioButton.value = true;
        myDialog.myVisibleBoundsRadioButton = add('radiobutton', undefined, "Visible Bounds");
        with(add('group')){
        orientation = 'row';
        alignChildren = 'center';
        spacing = 2;
        with(add('group')){
        alignChildren = 'right';
        var myXOffsetLabel = add('statictext', undefined, "Horizontal Offset:");
        var myYOffsetLabel = add('statictext', undefined, "Vertical Offset:");
        with(add('group')){
        myDialog.myXOffsetField = add('edittext', undefined, "0", {enterKeySignalsOnChange:false});
        myDialog.myXOffsetField.characters = 7;
        myDialog.myXOffsetField.justify = "right";
        myXOffsetField.onChange = function(){
        if(myValidateNumber(myXOffsetField.text)==false){
        alert("Invalid numeric entry!");
        myDialog.myXOffsetField.text = "0";
        myDialog.myYOffsetField = add('edittext', undefined, "0");
        myDialog.myYOffsetField.justify = "right";
        myDialog.myYOffsetField.characters = 7;
        myYOffsetField.onChange = function(){
        if(myValidateNumber(myYOffsetField.text)==false){
        myDialog.myYOffsetField.text = "0";
        with(add('group')){
        add('statictext', undefined, "points");
        with(add('group')){
        alignment = 'right';
        myDialog.myCloseButton = add('button', undefined, "Close", {name:'cancel'});
        myDialog.myCloseButton.onClick = function(){myDialog.close()};
        myDialog.myOKButton = add('button', undefined, "OK", {name:'ok'});
        var myReturn = myDialog.show();
        with(myDialog){
        var myTop = myTopCheckbox.value;
        var myLeft = myLeftCheckbox.value;
        var myBottom = myBottomCheckbox.value;
        var myRight = myRightCheckbox.value;
        var myXCenter = myXCenterCheckbox.value;
        var myYCenter = myYCenterCheckbox.value;
        var myXPoint = myXPointCheckbox.value;
        var myYPoint = myYPointCheckbox.value;
        var myXOffset = parseFloat(myXOffsetField.text);
        var myYOffset = parseFloat(myYOffsetField.text);
        if(myGeometricBoundsRadioButton.value == true){
        myBasedOn = 0;
        else{
        myBasedOn = 1;
        if(myEachObjectRadioButton.value == true){
        myRange = 0;
        else{
        myRange = 1;
        myDialog.close();
        else{
        else{
        myDialog.close();
      function myAddGuides(myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myRange, myBasedOn, myXOffset, myYOffset, myXPoint, myYPoint, myObjectList){
        var myLayer, myCounter;
        var myOldRulerOrigin = app.activeDocument.viewPreferences.rulerOrigin;
        app.activeDocument.viewPreferences.rulerOrigin = RulerOrigin.spineOrigin;
        //Create a layer to hold the printers marks (if it does not already exist).
        myLayer = app.activeDocument.layers.item("Guides");
        try{
        myLayerName = myLayer.name;
        catch (myError){
        myLayer = app.activeDocument.layers.add({name:"Guides"});
        //Process the objects in the selection.
        for(myCounter = 0; myCounter < myObjectList.length; myCounter ++){
        var myObject = myObjectList[myCounter];
        if (myBasedOn == 0){
        myBounds = myObject.geometricBounds;
        else{
        myBounds = myObject.visibleBounds;
        //Draw guides at path point locations, if necessary.
        if ((myXPoint == true)||(myYPoint == true)){
        myDrawGuidesAtPathPoints(myObject, myXPoint, myYPoint);
        //Set up some initial bounding box values.
        if ((myRange != 0)&&(myCounter==0)){
        myX1 = myBounds[1];
        myY1 = myBounds[0];
        myX2 = myBounds[3];
        myY2 = myBounds[2];
        if(myRange == 0){
        myDrawGuides (myBounds[1], myBounds[0], myBounds[3], myBounds[2], myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myLayer, myXOffset, myYOffset);
        else{
        //Compare the bounds values to the stored bounds.
        //If a given bounds value is less than (for x1 and y1) or
        //greater than (for x2 and y2) the stored value,
        //then replace the stored value with the bounds value.
        if (myBounds[0] < myY1){
        myY1 = myBounds[0];
        if (myBounds[1] < myX1){
        myX1 = myBounds[1];
        if (myBounds[2] > myY2){
        myY2 = myBounds[2];
        if (myBounds[3] > myX2){
        myX2 = myBounds[3];
        if(myRange != 0){
        myDrawGuides (myX1, myY1, myX2, myY2, myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myLayer, myXOffset, myYOffset);
        app.activeDocument.viewPreferences.rulerOrigin = myOldRulerOrigin;
      function myDrawGuidesAtPathPoints(myObject, myXPoint, myYPoint){
        for(var myPathCounter = 0; myPathCounter < myObject.paths.length; myPathCounter++){
        for(var myPointCounter = 0; myPointCounter < myObject.paths.item(myPathCounter).pathPoints.length; myPointCounter ++){
        if(myXPoint==true){
        myDrawGuide(myObject.paths.item(myPathCounter).pathPoints.item(myPointCounter).anchor[0], 1);
        if(myYPoint==true){
        myDrawGuide(myObject.paths.item(myPathCounter).pathPoints.item(myPointCounter).anchor[1], 0);
      function myDrawGuides(myX1, myY1, myX2, myY2, myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myLayer, myXOffset, myYOffset){
        if (myTop == true){
        myDrawGuide(myY1 - myYOffset, 0);
        if (myLeft == true){
        myDrawGuide(myX1 - myXOffset, 1);
        if (myBottom == true){
        myDrawGuide(myY2 + myYOffset, 0);
        if (myRight == true){
        myDrawGuide(myX2 + myXOffset, 1);
        if (myXCenter == true){
        myDrawGuide(myX1+((myX2-myX1)/2), 1);
        if (myYCenter == true){
        myDrawGuide(myY1+((myY2-myY1)/2), 0);
      function myDrawGuide(myGuideLocation, myGuideOrientation){
        var myLayer = app.activeDocument.layers.item("Guides");
        with(app.activeWindow.activeSpread){
        if(myGuideOrientation == 0){
        with (guides.add(myLayer, undefined, undefined)){
        orientation=HorizontalOrVertical.horizontal;
        location=myGuideLocation;
        else{
        orientation=HorizontalOrVertical.vertical;
      function  myValidateNumber(myString){
        var myRegExp  =  /(^-?\d\d*\.\d*$)|(^-?\d\d*$)|(^-?\.\d\d*$)/;
        return myRegExp.test(myString);
      Advance Thanks,
      K
