3 Replies Latest reply on Apr 26, 2017 1:38 PM by Rick Gerard
    Rotating 2D bottle
    andreashoj
      Hello,
      I'm new to After Effects an took upon a task to showcase a bottle (the bottle is drawn in illustrator).
      I want the bottle to do a 360 showcasing the label.
      If anyone could point me in the right direction I'd appreciate it a lot!
        • 1. Re: Rotating 2D bottle
          There is no such thing. It's just a flat layer. You have to use a 3D program to create genuine 3D geometry and throw your label as a texture onto it.
          Mylenium
          • 2. Re: Rotating 2D bottle
            andreashoj Level 1
            Alright thanks for the answer!
            • 3. Re: Rotating 2D bottle
              You could make a graphic that shows the front and back of the bottle like you were going to print a label. Then you make an illustration of your bottle wihout a label.
              Now you import both images with the label on the top layer. Then you add CC Cylinder to the label illustration, set it to render outside only and rotate the label to make it look like the bottle is rotating. With careful alignment you can do a pretty good simulation of rotating a bottle.
              By far the best way to create the effect is to model the bottle in a 3D app and apply textures but you can certainally fake it with AE.
