1 Reply Latest reply on Apr 26, 2017 3:00 PM by Roei Tzoref
    Psd file layers have turned black.
    Fragjaw12
      I have imported a psd file into after effects. The file imported but whenever I bring it into the composition it turns some layers black (bottom photo). It should look like the top photo.should look like.png.problem.png
        • 1. Re: Psd file layers have turned black.
          Roei Tzoref Adobe Community Professional
          seems your PS shape layers are not interpreting correctly. you are using CS6 and it does rasterize strokes of PSD layers correctly when it's set to "editable layer styles". import the PSD file again and change it to "merge layer styles" in the layer options upon import. you won't get the mask paths, but that is actually good if you do not intend to animate the path itself.
