I'm struggling with some issue which I suspect belongs to the build process: After having ported my UI plugin to CC 2017, it is not loaded by InD..
- I'm able to compile sample plugins which are loaded successfully (e.g. BasicPersistnterfaceUI, so it looks like my DEV environment is good, OS X 10.11.6, XCode 8.2.1, InD 12.1.0.56)
- Same holds for my model plugin
- I've put some log print into SDKPluginEntryPoint.cpp which isn't printed for the UI plugin (that's why I concluded it is indeed not loaded)
- I'm not able to find any hint in the build/Terminal/Console log
Any idea of what I might have missed?
Help really appreciated!
Cheers, Bastian
Have you checked that all your resources are included correctly into the compiled plug-in ? Try "Show package contents" on your plug-in and compare what you see to a plug-in that loads.
Regards,
Thomas
There could be many reasons for the plugin not loading.
One easy way to figure it out is to check in the InDesign debug version.
InDesign debug version should be able to spot the issue.
Please get the InDesign Debug version from the pre -release forum.
