1 Reply Latest reply on Dec 9, 2008 12:06 PM by Newsgroup_User
    mpg to flv conversion
    Level 7
      Best method for .mpg to .flv conversion? I have the Master Collection CS3,
      but I still have to download an flv converter tool???
        • 1. Re: mpg to flv conversion
          Level 7
          txwebdesigner2,
          > Collection CS3, but I still have to download an flv converter
          > tool???
          You have that option, if you want more than the default choices
          supported by Flash CS3 -- but no, you don't have to download an FLV
          converter. To convert your MPG to FLV, you can either use the Flash CS3
          Video Encoder (ships with Flash) or Flash CS3 itself. Just import the MPG
          file and run through the various configurations to output an FLV file.
          Flash CS3 gives you single-pass encoding, which might meet your needs
          just fine. If you want two-pass encoding, you'll have to look into a 3rd
          party tool, such as On2's Flix Pro or Sorenson's Squeeze. (They also give
          you additional parameters to tweak, because they're specifically video
          conversion apps.)
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
