2 Replies Latest reply on May 2, 2017 3:20 AM by Parthiban.Kumaravel
    AcroPDF throwing exception when used in x64 Application
    Parthiban.Kumaravel Level 1
      I am facing few issues in rendering PDF document in the 64-bit environment. The same source code is working fine in the 32-bit environment.
      Application Build Plat Form Target: x64
      In the project, the below DLL's were referenced
      1. AxInterop.AcroPDFLib
      2. Interop.AcroPDFLib
                  this.axAcroPDF1 = new AxAcroPDFLib.AxAcroPDF();
                  ((System.ComponentModel.ISupportInitialize)(this.axAcroPDF1)).BeginInit();
                  this.axAcroPDF1.Dock = System.Windows.Forms.DockStyle.Fill;
                  this.axAcroPDF1.Enabled = true;
                  this.axAcroPDF1.Location = new System.Drawing.Point(0, 0);
                  this.axAcroPDF1.Name = "axAcroPDF1";
                  this.axAcroPDF1.OcxState = ((System.Windows.Forms.AxHost.State)(resources.GetObject("axAcroPDF1.OcxState")));
                  this.axAcroPDF1.Size = new System.Drawing.Size(800, 0);
                  this.axAcroPDF1.TabIndex = 16;
                  ((System.ComponentModel.ISupportInitialize)(this.axAcroPDF1)).EndInit();
      While executing the above code exception is thrown at the line
      Exception Message:
                A first chance exception of type 'System.BadImageFormatException' occurred in System.Windows.Forms.dll
                Additional information: Could not load file or assembly 'Interop.AcroPDFLib, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies.           An attempt was made to load a program with an incorrect format.
      Is there any solution to overcome this issue?
      Thanks in advance
      Parthiban Kumaravel
