Per MikeGondek's advice, I am starting my own post.
I have tried Mike's suggestion for resetting my OOBE & Cloud Cache, and also dumped my preferences. None of those helped.
Opening a simple B&W Illustrator file took 00:01:42 (almost 2 minutes) with Illustrator already up and running. I added the trademark (ā¢) symbol and closed and saved the file. Closing and saving the file took 00:0056 (almost a minute).
System stats:
iMac (21.5)
2.9 GHz Intel Core i5
16 GB 1600 MHz DDR3
NVIDIA GeForce GT 750M 1024 MB
Illustrator:
Adobe CC 2017.0.2 Release
Illustrator 21.0.2
Yes yes yes that helps, what I originally suspected in your case. That error you have from the creative cloud trying to initialize should be your issue, and what we need to focus on resolving.
Restart, go straight to the cloud and quit. Check activity monitor that all Adobe and Adobe cloud are quit, you may need to force quit each Adobe process manually, wish you could select multiple items. Remove the OOBE files. Start the cloud and if you have no errors that Illustrator should work.
You may be a
...Copy link to clipboard
Hi Gavin,
Hang in there, being on the Mac am confident we will get this resolved.
I believe this started with CC 2017. I still have CC 2015.3, and ran a test between the two. CC 2017 opened my test file in 1:41 and CC 2015 opened the text file in 1:44.
I use InDesign, Photoshop, and Acrobat DC, all of which seem to work fine.
Yeah, that pretty much seems to decide on a daily/hourly basis whether it wants to show or not. Opened it up after reading your thread, though, and got this weird message.
Pretty sure, yes. There was no Creative Cloud icon showing in the status bar, and restarting Illustrator created a new set of those.
Yes, all editing seems normal. Drawing elements, adding/deleting swatches, etc.
Our files are stored on Windows (not my choice), but we access them through AFP. Before we talked IT into that, we were accessing via SMB, and that was unbearable!
Oops, forgot to mention that detail. Sierra, latest public build.
No other Illustrator plugins, except a font server: Universal Type Client. As far as System Software, what would you qualify on that. Giving a full list of software we run would be exhausting.
Left to right: Location (built-in service ā probably had maps open sometime today, but that's a rarity), 1Password (password vault), PopChar (glyph chart), Fantastical (natural language alt to Mac's calendar app), Google drive, Dropbox, Hazel (RBA), keychain access (built-in service), Time Machine (built-in service), Bluetooth indicator (for the Magic Mouse 2).
Hope this helps.
Is there a way I can send one of these files and see how long it takes to open on your computer?
You may be able to avoid the activity monitor if you get a good quit from cloud. That is why I suggest a restart. But all the red icons you need to quit and here are most of them.
It is usually one of the 3 .db files, and you should notice atleast one of them get smaller after cleansing.
Cool. I'll give that a try. Also, when I finally did get Creative Cloud to come up, it showed an update to Illustrator, so I ran that.
I'll report back.
Thank you so much! I had the same problem and this helped me too!
Adding your instructions for OOBE dump here, should some other poor sap need it later.
RESET CLOUD OOBE
Mac
Quit Illustrator & Creative Cloud (go to cloud icon on top right, click on gear icon, quit)
Mac Finder >> Shift Command G
enter: ~/Library/Application Support/Adobe/OOBE
Move your OOBE folder somewhere (eg: desktop)
Windows
Exit Creative Cloud app
remove the opm.db file located here: C:\Users\<user>\AppData\Local\Adobe\OOBE
That did the trick! Thanks MikeGondek for sticking with me through this!
Files open in 8.7 seconds
Close and save in 3.5 seconds
Much better!!
Hi Gavin,
Glad to hear opening and saving is much faster now.
Thankyou for setting an example of how to post on the forums, by listing your operating system, plug-ins and providing good feedback and variables needed to address your issue.
You may be doing this already, but you can also do a save as and turn OFF pdf compatible for an added speed increase and smaller file sizes.
Gladly.
Is there a way to just turn off PDF compatible in the settings, rather than having to do a "Save As" every time?
There actually is
This will hold until the next timer you reset your prefs, and will work on new files you create. Existing files you will need to do a saves as to turn that off.
Weirdly, no such setting in mine.
My screenshot earlier was from 2015, I tried in 2017 and found also.
Try searching for the word Compatibility. If does tho show up, then I guess you could back up your prefs and try adding the line as shown in my screenshot. You could always go back if something drastically goes wrong, or reset your prefs.
Well, back to 2 minutes to open a file and 1 minute to save. So, apparently the dumping of the OOBE folder was not a permanent solution.
How is your creative cloud app doing, any error messages or updates running background? Might your account have been installed on more than 2 computers? Are you syncing libraries or fonts?
Weirdly, CC did not start up with the computer startup, even though individual apps did. So, I turn off "Launch at Login," quit CC, then started it again manually, and turned "Launch at Login." I then logged out, and logged back in and now it starts up with login.
Only installed on 1 computer, although we have a site license, and we don't use CC libraries or fonts. We use a Universal Type Server, from Extensis. Checked for updates, too, and there are none.
Just checking and I see that CC has turned font and file syncing back on in preferences, so I have turned those back on again. Maybe that will help.
Just for kicks, since I was doing a ton of vector logos last night, and pulling my hair out all along the way, because of the slowness ā I went through all steps in this post again, carefully and in order, leaving out nothing. It still did not solve the slowness, and Adobe Creative Cloud still decides on it's own when if wants to start with computer boot. I still get the "longer than usual to initialize" message, and even tried uninstalling and reinstalling the whole thing.
Nothing has helped.
Hate to recommend the long way to fix a problem, but if you have good internet speed will not take too long.
Use the Creative Cloud Cleaner Tool to solve installation problems
That may hopefully get your cloud to boot itself normally and resolve all this.
Hey, I'm about ready to try anything right now, up to and including wheeling this workstation out into the middle of the street in front of a Mack truck. š
Giving the CCCT a try now.
May the Creative Cloud force be with you.
Ran this, and uninstalled EVERYTHING, including the individual programs and the CC program itself. Walked through the whole process, step by step. Finally got everything reinstalled this morning, only to find that nothing was solved. Still 2 minute to open a file, and 1 minute to save.
Pretty frustrating!
Create a new file a draw a rectangle, does that happen to that file? A nested symbol, or overlapping masks & paths which serve no purpose or the deleted global colors problem, could drive postscript into loop of madness. Just want to rule out 100% that this is not something in the file.
I believe the cleaner flushes the OOBE, but you had success with that in the past so you could try that again. I have done the OOBE flush on dozens of machines to resolve issues, and they have never needed a second flush in such a short amount of time. At post 6 you were doing great so would recommend to quit cloud and try OOBE flush again.
A main symptom was that your cloud app was not acting normally, so any progress on how that is functioning would be helpful.
Have not yet heard that something outside of Adobe can conflict with you adobe cloud. Have never used hazel (is at at the cleaning utility) or could possibly be google cloud be conflicting?
@ohmath could use your help on this and this post might be of interest to the adobe team.
Tried the OOBE flush again, with no luck.
The simple new file with plain rectangle took 02:26:46 to save. And it took 01:28:36 to reopen.
Hazel is an Automator GUI (basically). Quitting it did nothing to help the time.
Re: Google Cloud or Dropbox. I tried turning them off, and still no love.
Re: the main Creative Cloud app, I completely uninstalled EVERYTHING, and reinstalled. And it still doesn't come up at launch. Launched manually, it still comes up with the "Creative Cloud seems to be taking longer than normal to initialize" error.
Would say the cloud is what is causing you Illustrator to be slow.
Adobe Creative Cloud desktop app doesn't open or shows a spinning progress wheel
But we have done all this, so we may be onto a new twist that needs to be added to this technote. Will try to send a private message to someone at Adobe, as they can log into your computer with you permisson which should help resolve this.
Thanks.
When CC finally came up, I changed it's preferences to NOT open at login. Then quit. Then restarted the app and changed preferences again to open at login. Quit the app and restarted the app, just to check that the preference held.
Then I rebooted the computer, and CC came up just fine. Saving the simple rectangle took 01:30:16, but opening it was around 00:12:20. making a simple change to it and saving it was 0:25:57. Much better, except that initial save.
I'm going to reboot again, and make sure those hold and that CC still boots up on it's on at login, and will report back.
