1 Reply Latest reply on Apr 27, 2017 12:15 PM by ryanskihead
    Phonegap build error (app 2528910)
    reminous_plus
      Hi
      I created an application on Intel XDK and exported it to Phonegap to the build, but the error below appears without able to solve:
      --- LOG
      :processReleaseResources/project/build/intermediates/res/merged/release/values-v24/values- v24.xml:3 : AAPT: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Borderless.Colored'.
      /project/build/intermediates/res/merged/release/values-v24/values-v24.xml:4 : AAPT: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Colored'.
      FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':processReleaseResources'.
      > com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '/android-sdk/build-tools/24.0.1/aapt'' finished with non-zero exit value 1
