8 Replies Latest reply on Aug 24, 2017 8:53 AM by oksamurai
    Handle Tags not showing up in properties (WALK)
    Lupillo Arellano Level 1
      I've been working and learning CA now since December, and I'm loving it. I created a regular full on puppet and it works great.
      I just now started to play with the Walk Cycles, and I created a new side-view puppet for this purpose. I followed the video tutorial and my puppet would not walk. I got two of the heads (it has five heads) to bob up and down, disconnected from the body (*note below that those two heads' tags do show up in the WALK handles properties, and FYI I added fixed points on the head and did exactly as I did on my first original puppet, and only 2 of the 5 heads bounce while walk cycle is in effect).
      I realized that the tags I was creating for the body, the limbs and heads were not showing up in the WALK handle properties. I have tagged them correctly, I've removed the tags and re-added them, yet they don't show up. I've tried closing the app and reloading, nothing.
      I downloaded WALKBOT, and I removed tags and re-added them successfully. It's just not working on my puppet.
      I have rigged all the points just as the video tutorial shows (head, heels, toes, ankles, knees, wrists, etc.), but they don't show up in the WALK handles properties...
      Here are screen captures of the Right Heel so you can see what I mean:
      And here are the handles properties/tags for the WALK cycle behavior (notice that two heads are listed in the tags, the left and right profile, and those two do bounce up and down in the walk cycle, but detached from the main body). All the other tags that I created don't show up:
      The only thing that I added/did differently from the video tutorial is I used a contour mesh (rather than auto) for the puppet (same as I did in the first original working puppet).
      Any idea why this can be happening? Why the tags aren't applying in the Walk Cycle?
        • 1. Re: Handle Tags not showing up in properties (WALK)
          One other thing that may be causing this error is that puppet's name is the same as my previous puppet. The files are named differently, but the actual puppets used to rig have the same names. Therefore, I have two puppets available in CA- the original one that works fine and this new walking one (both have the same name for the actual puppet, but different file names). Could that be the problem?
          • 2. Re: Handle Tags not showing up in properties (WALK)
            oksamurai Employee Moderator
            Yeah. If the handles are showing up in the puppet panel but not in the walk behavior pulldown, then the Walk behavior can't find them for some reason.
            The issue seems to be that the Walk behavior is finding the "Left Profile" and "Right Profile" for your head and latching onto that instead of the body. See under "Views" in the Walk dropdown - that's what it's showing.
            My advice would be to check out how Maddie is set up here and emulate her: http://adobe.com/go/chexamples. She has head turns + a three view walk. I think the issue is that you only have one head group, where in Maddie she has each of the views at the top level - Frontal, Left Profile, and Right Profile - each with its own head and body. That's the route I would take too, so Walk picks up on those top level views instead.
            • 3. Re: Handle Tags not showing up in properties (WALK)
              Thank you for the response, and after extensive testing I have found that your suggestion helped.
              When the first versions of CA were in use, the head turner behavior was included. So, as per the many tutorials available for CA, most people built their puppets with two main upper-level layers- the body and head.
              The head was setup with the following layers: "FRONTAL" or "FRONT", "RIGHT PROFILE", "RIGHT QUARTER", "LEFT PROFILE", LEFT QUARTER". This allows the head turner behavior to read, and tag, each head separately:
              PUPPET NAME
              -BODY
                   -LEFT ARM
                   -RIGHT ARM
                   -TORSO
                   -LEFT LEG
                   -RIGHT LEG
              -HEAD
                   -FRONT
                   -RIGHT PROFILE
                   -RIGHT QUARTER
                   -LEFT PROFILE
                   -LEFT QUARTER
              The problem is this- the new version of CA (version 6) looks for the same labels ("FRONTAL" or "FRONT", "RIGHT PROFILE", and "LEFT PROFILE"), and it does not differentiate whether they are for a HEAD label or for a FULL BODY label.
              Solution- we now need to create a new puppet with three FULL BODY profiles ("FRONTAL" or "FRONT", "RIGHT PROFILE", and "LEFT PROFILE", and within these profiles we need to further create layer for the body and for the head, and inside the head we need to add the head turner layers ("FRONTAL" or "FRONT", "RIGHT PROFILE", "RIGHT QUARTER", "LEFT PROFILE", LEFT QUARTER"):
              PUPPET NAME
              -FRONTAL
                  -BODY
                   -LEFT ARM
                   -RIGHT ARM
                   -TORSO
                   -LEFT LEG
                   -RIGHT LEG
                  -HEAD
                   -FRONT
                   -RIGHT PROFILE
                   -RIGHT QUARTER
                   -LEFT PROFILE
                   -LEFT QUARTER
              -RIGHT PROFILE
                 -BODY
                   -LEFT ARM
                   -RIGHT ARM
                   -TORSO
                   -LEFT LEG
                   -RIGHT LEG
                  -HEAD
                   -FRONT
                   -RIGHT PROFILE
                   -RIGHT QUARTER
                   -LEFT PROFILE
                   -LEFT QUARTER
              LEFT PROFILE
                  -BODY
                   -LEFT ARM
                   -RIGHT ARM
                   -TORSO
                   -LEFT LEG
                   -RIGHT LEG
                  -HEAD
                   -FRONT
                   -RIGHT PROFILE
                   -RIGHT QUARTER
                   -LEFT PROFILE
                   -LEFT QUARTER
              Of course, this gives us three times the work, but the results are 100% worth it. The ability to walk, left and right, or to face forward, is incredible. Add the head turner ability to each of those walking parameters and it becomes even more amazing.
              I suggest that you (ADOBE) differentiate the naming structure, for example LEFT PROFILE HEAD and LEFT PROFILE FULL BODY so that when we label and create our puppets CA will know how to separate and differentiate between the layers and structures. This might be a good idea to bring up in your upcoming tutorials and tips & tricks.
              Thank you so much, and as I continue to learn to use the app, I become a bigger and bigger fan of CA!
              • 4. Re: Handle Tags not showing up in properties (WALK)
                Glad you figured it out. And I agree, we could be clearer with those views - definitely something to consider for the future, thanks!
                • 5. Re: Handle Tags not showing up in properties (WALK)
                  Amanda_Armstrong Level 1
                  I was frustrated with having to rig 7 heads (I included UPWARD and DOWNWARD) three different times, but found a work around.
                  1. Rig all of your views in one head group.
                  2. Right click the head and choose "Make 'HEAD' Shareable." This creates a stand-alone puppet out of your head (or anything else you decide to do this with)
                       3. You can then drag the rigged head from the project panel into the "Frontal, R Profile, and L Profile" body views in the puppet panel.
                  You do have to re-position the head after doing this, but that's no big deal compared to having to re-rig keyboard triggers etc. for so may views!
                  Hope this helps a bit!
                  2 people found this helpful
                  • 6. Re: Handle Tags not showing up in properties (WALK)
                    El Wombat Level 2
                    On the walk behavior tagging issues:
                    I solved it now, by even closer emulating the puppet structure of Maddy from Athena Studios. Those guys have been doing a great job!
                    The tags / handles of the walk behaviour just didn't show up until I (re-)installed tags for "right profile" (view) for my full puppet RIGHT PROFILE view for walking to the right.
                    This being said, I would really like to understand how this works, I feel a bit like a toad jumping around the keyboard at the moment, squeaking when something nice happens, but not knowing why…
                    Quoting Dave: "The issue seems to be that the Walk behavior is finding the "Left Profile" and "Right Profile" for your head and latching onto that instead of the body. See under "Views" in the Walk dropdown - that's what it's showing."
                    Sorry but I still don't really get my head around it…
                    ___________-
                    On Amandas workaround for the head rigging:
                    I owe you! This is just great! I am working on a puppet structured like Maddy and I was on the point of rigging all of the three heads 5 to 7 times each. Each with lots of independent hairstrands, each with complicated mouths in which most visemes have cycle layers to them.
                    And I simply hadn't thought of that possibility to reproduce a head by making it a sub-puppet… So no, this doesn't help a little, you saved me HOURS of time. Thanks a lot!
                    • 7. Re: Handle Tags not showing up in properties (WALK)
                      I've taken sharing puppets to another level by sharing the "right-walking" body of a puppet, adding it to the "left-walking" puppet, reversing the body, and that's it. Now I have a right-walking and left-walking body with half the work.
                      The issue I've seen is that if you change the original work file (illustrator file for me- name changes, etc.), it will cause an error in the puppet and lots of the rigging will be lost. I believe this has to do with the shared puppet parts being renamed or redone; I'm hoping it will get fixed in the upcoming updates. If it is fixed then you'll be able to create a counter left puppet.
                      • 8. Re: Handle Tags not showing up in properties (WALK)
                        Yes - if you make major renaming or structural changes to your file, CH can't reconcile everything and will think it's all new groups/layers. So ideally you want to do most of your artwork/structure pre-rigging.
                        But yes - this is a known issue and will improve in the future.
