0 Replies Latest reply on Nov 27, 2008 12:00 PM by vrthree
    Transitions and stuff
    vrthree
      I have put together a slide show where I have scaled up/down the images to give a bit of movement. I used key frames and motion tweening to do this. I also want to add fade in and out between the images. I am aware you can add transitions using key frame animation as well. The problem I am having is if I add a transition using a keyframes it corrupts the movement in the image. Is there away of adding a transition without using keyframes and keeping the motion tweening intact?
      Hope this makes sense.
