4 Replies Latest reply on Jan 5, 2009 7:35 PM by John Hall
    "in" relational operator
    DPFrazier Level 1
      We're trying to figure out how to use the "in" operator in arraycollection filterfunctions. For example,
      return item.ID in <some string or array or collection>
      Does anyone have experience with the "in" operator and what types of operands it works with?
      Dean
        • 1. Re: &quot;in&quot; relational operator
          Level 7
          "DPFrazier" <webforumsuser@macromedia.com> wrote in message
          news:gjtsae$jfr$1@forums.macromedia.com...
          > operands
          > it works with?
          I think maybe you want contains()?
          • 2. Re: &quot;in&quot; relational operator
            DPFrazier Level 1
            > operands
            > it works with?
            Thanks for your reply, Amy.
            I took a look at contains, and it appears to give a true/false on whether the operand is in the collection. Don't know if it works on 2D collections, or with multi-value operands (either an array, or CSV string), but I don't think it's going to give us what we are looking for.
            I'm trying to replicate the IN filter of SQL, where records are extracted based on whether a particular field matches one of the values in a CSV string. The idea is to bring all the data in from the database (we need it for other purposes anyway), and then filter locally using a filterfunction.
            Any other ideas?
            Dean
            • 3. Re: &quot;in&quot; relational operator
              Level 7
              news:gjua31$7ej$1@forums.macromedia.com...
              > > arraycollection
              > > operands
              > > it works with?
              > the
              > or
              > think
              > string.
              > other
              > Any other ideas?
              That's how I'd do it. I usually maintain one version that's unfiltered for
              "everything" work and another that's filtered for more targeted operations.
              I don't think you get to supply additional arguments to a filter
              function--you'll just need to have a variable or set of variables that it
              knows to look at. One possible approach is to create a custom class just
              for filterFunctions and then give it one or more properties that can be set.
              Then use something like
              myInstance:myFilterClass=new myFilterClass();
              myInstance.properties = {prop1:'value of prop 1', prop2:4};
              myArrayCollection.filterFunction=myInstance.filterFunction;
              You may also want to look at IViewCursor and see if that is helpful.
              HTH;
              Amy
              • 4. Re: &quot;in&quot; relational operator
                John Hall Level 4
                Not that this link is relevant to your specific situation, but I've found this link useful for multiple filters
                http://blog.rotundu.eu/flex/arraycollection-with-multiple-filter-functions/
                might tuck it away in your bookmarks
