5 Replies Latest reply on Sep 5, 2018 11:10 AM by angie_taylor
    Animated Handwriting
    Suntower Level 1
      90% sure this is not the correct forum, but ya gotta start -somewhere-. Sorry if these seems so 'noob'.
      I want to create an animation for insertion into a Premiere video, the contents of which is the old cliche of handwriting appearing out of thin air.
      I mean as if I were using using a screen recording program and drawing (or rather 'handwriting' with my wacom tablet) live in Photoshop or AI) on a transparent background.
      Except that I want to 'record' that handwriting 'performance' such that it goes into a PSD animation or into an After Effects file or an AVI file or -something-... I have no idea -what- at this point. All I know is that I want to handwrite with my pen/tablet and have a file that I can import into Premiere.
      The ultimate goal is to put it into an instructional video.
      What would be a good tool for doing this sort of thing?
      TIA,
      ---JC
        • 1. Re: Animated Handwriting
          macpawel Adobe Community Professional
          You can do it in Animate, After Effects and maybe Premiere - try tu use masks
          First write your text and then use animating mask to reveal it
          Pawel
          • 2. Re: Animated Handwriting
            andreip14565073 Level 1
            You can quite easily do it in after effects.
            The technique is to draw a line over the actual text, as you would write it(this will create the mask).
            Then go to this line properties and add trim paths. This will enable you to set the ending point of it, creating the write-on effect.
            Then set the track matte type of the text(wich has to be under the line in the layers window) to alpha matte, so it will only be visible when the above line "exists".
            If you don't have a specific font in mind, and would be willing to choose from some, audaciousleap has a little collection of automated scripts doing this thing with some fonts.
            • 3. Re: Animated Handwriting
              Daniel Presedo > dramenon Adobe Employee
              Seems the best course of action is some form of "Screen Recording" to simulate the hand writing.
              Here is one approach I have done myself:
              You can actually record brush strokes in Photoshop as an Action and then play it back. It cannot be used in Premiere but if you were to do a screen recording you can record it one way change brush strokes and record it again. Different takes with different brushes all using your one time recording with a Photohsop Action.
              It's not the most streamlined workflow but it works and the files tend to be large. If you plan to do a one-off and you can screen record it then it might be a useful experiment. At the very least you will have learned what few have ever seen
              This is the tutorial from my YouTube Channel.
              And, as I mentioned, if you were to use a screen recording tool with Photoshop > Just enter Full Screen mode and you could make a screen capture video and then use it in Premiere.
              Good luck!
              • 4. Re: Animated Handwriting
                angie_taylor Adobe Community Professional
                In After Effects you can actually write your text on Screen with the Brush tool. If you make sure the Paint mode is set to “Write on” then it will automatically animate when you play it back. This is by far the easiest technique if you want to write it by hand. If you need more control over the shapes of the letters you can copy and paste paths from
                Illustrator into an AE
                layer as Masks. Then use the Scribble or Stroke effect to create the animated strokes on these masks. As
                somebody mentioned, you could us Trim
                Paths on shape layers but its a bit more
                fiddly, particularly if youre not used to using Shape
                layers. The other methods are very easy.
                • 5. Re: Animated Handwriting
                  Dear moderators. The answer that is marked as correct here is not really a correct answer. Thats how to create a reveal which is not what is being asked. They want to animate handwriting as its drawn.
