Hi Devs,
I use Dreamweaver since the early versions of Macromedia and the latter two versions (CC 2015 and CC 2017) are the worst I've ever used.
The software is extremely slow to perform any process. This is slow to load the files and does not generate productivity when writing some code.
I started using Netbeans to work and will downgrade to CS6 or CC 2014 version.
Have a look at this discussion Re: Dreamweaver CC 2017 ultra slow and freeze continually and see if that helps.
I subscribed to the whole Adobe App servie and installed CC 2017.
My Mac hardware is as follows so had resonable expectations...
Processor Name: Intel Core i7
Processor Speed: 2.3 GHz
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 6 MB
Memory: 16 GB
Unfortunately since then, I've had nothing but performance related problems, in particular cache refreshes and generally working on code with JS.
I have spent many months searching and viewing forums to identify cause and solution. Apart from random fixes which have worked for individual setups, there is nothing coming out of Adobe accepting that CC 2017 performs poorly across the board with constant freezing and lagging issues ocurring with every session.
I've now got to the point where patience has worn out and I have installed CS6 which i know worked fine!
Doing so has of course reinastated the extention manager, server behaviours and i am now able to use all my DMXZone and Webassist extentions without issues.
Theres too much failing in CC 2017. I'm more than happy to remain with CS 6 - that is until adobe provide a major release to CC2017 which meets my needs.
I'm even able to use the creative cloud to host my files, so that's a bonus with CS6.
