• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
After Effects CC 2017 doesn't render full video or audio
New Here ,
Apr 29, 2017 Apr 29, 2017
I'm using a Macbook Pro OS X and After Effects CC 2017. When I render a composition, which includes animation and a .wav audio file, it renders for the full time-frame, but the animation and audio stop a couple seconds in. I'm left with a silent, still image for the remainder of the time. It previews just fine. I've checked the render settings and they seem fine. I'm rendering to Photo-JPEGs at 30 f/s at the highest quality. What gives?
Views
5.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
also, what resolution are we talking about? how are you previewing your file?
try this: drag your footage to Ae and load it to cache (numpad 0 set it to cache before preview) and preview it. does it preview fine?
Votes
Translate
Translate
Report
Report
New Here ,
If I cache the .mov file in AE, it does play, but only 200 frames or so at a time. Is there no way to play it in Quicktime?
Votes
Translate
Translate
Report
Report
LEGEND ,
I wanted to make sure there isn't a problem with you video, just with the playback. Photo-Jpeg isn't the best codec for playback, it's considered a virtually lossless codec and usually not for playback purposes. if you wan't a decent playback, you should render your video Through Adobe Media Encoder with H.264 preset. see it here: Basics of rendering and exporting in After Effects CC
Votes
Translate
Translate
Report
Report
New Here ,
Apr 30, 2017 Apr 30, 2017
Thanks for your help, Roei. It seems it will play in pieces in AE. I'm still not sure how to view the whole thing. I'll check out the link you sent.
Votes
Translate
Translate
Report
Report
LEGEND ,
May 02, 2017 May 02, 2017
AE's preview caches to your RAM. If you want to preview your whole thing, you will need to either add more RAM or reduce the requirements. Most AE professionals don't preview their whole comp at full resolution, by the way. Spot check things here and there, sure, but not the whole thing at full size.
Change your comp down to half resolution and it should be able to cache a lot more of it.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
May 24, 2017 May 24, 2017
Hi Kaia,
Were you ever able to export your video? Please let us know if you did or if you still need help.
Kevin
Votes
Translate
Translate
Report
Report
New Here ,
Apr 01, 2018 Apr 01, 2018
LATEST
I'm also having the same problem as well. When i try to render the video it stops a few seconds. Do you know any way to fixing this? Even when i put it in adobe Media Encoder it stops at the same place.
Votes
Translate
Translate
Report
Report
