4 Replies Latest reply on Apr 30, 2017 3:01 PM by sargums46564804
    How do I keep original selection showing in drop down list
    sargums46564804 Level 1
      I have this code which loops and labels documents:
      var oDocNumTypes = {
      "Exhibit":{Prefix:"A"},
      "Attachment":{Prefix:"B"},
      "Memo":{Prefix:"C"},
      "Sample ":{Prefix:"D"},
      The user has to select the document type from a drop down list.  After the user selects "Exhibit" for instance from the drop down list, it labels the first document and then the second , third and so on.  However, the chosen value of "Exhibit" disappears from the drop down list.  I want it to remain throughout the looping so user does not get confused and think they need to keep selecting it each time.  How can I do this?
      Original selection:
      Does not retain original selection...Defaults back to showing nothing through loops
      I am using Adobe Acrobat Pro X 10.1.16 on Windows 7.
        • 1. Re: How do I keep original selection showing in drop down list
          Is this a dialog object in an Action? Something else? Please clarify.
          • 2. Re: How do I keep original selection showing in drop down list
            The answer is yes.
            Here are excerpts of the code I think are relevant:
            oDocNumParams:oDocNumTypes,
                    initialize: function(dialog)
                        var listLTyp = new Object();
                        this.SetListSel(listLTyp, this.strLTyp);
            "LTyp": function(dialog)
                        var oRslt = dialog.store();
                        var path = [];
                        var cSel = ((this.GetListSel(oRslt["LTyp"],path))?path.reverse():"").toString();
                        var oLabInfo = this.oDocNumParams[cSel];
                        if(!oRslt["DNum"] || (oRslt["DNum"] == "") || isNaN(oRslt["DNum"]))
            dialog.load({"DNum":"1"});
                        if(oLabInfo)
            dialog.load({"LPfx":oLabInfo.Prefix, "DocN":oLabInfo.UseDocNum, "PgNm":oLabInfo.UsePgNum, "PPfx":oLabInfo.PagePrefix});
            dialog.enable({"DNum":oLabInfo.UseDocNum, "PPfx":oLabInfo.UsePgNum, "PPsf":oLabInfo.UsePgNum});
                          this.SetDocNumber(dialog,this);
                    "PosB": function(dialog)
            dialog.enable({"MrgV":false});
                    "PosT": function(dialog)
            dialog.enable({"MrgV":true});
                    "PosR": function(dialog)
            dialog.enable({"MrgH":true});
                    "PosC": function(dialog)
                    "PosL": function(dialog)
                    description:
                        name: "Automatic Batch Labeling Application",
                        elements:
                                type: "view",
                                elements:
                                        type: "view",
                                        alignment: "align_fill",
                                        elements:
                                                type: "view",
                                                height: 14,
            align_children: "align_top",
                                                elements:
                                                        type: "static_text",
            item_id: "FlNm",
            name: "Please enter the information for applying document numbering labels to:",
                                                        height: 14,
            font: "palette",
            bold: true,
            item_id: "sta1",
            name: "Version 1.6.1 - 1/6/17 SCS/CA",
            height: 12,
                                                        alignment: "align_right",
                                                type: "cluster",
                                                item_id: "cls2",
                                                name: "ENTER LABEL INFORMATION",
                                                font: "palette",
                                                bold: true,
                                                elements:
            type: "view",
            align_children: "align_row",
            elements:
            item_id: "sta3",
        name: "1. Select Document Type:",
            type: "popup",
        item_id: "LTyp",
            variable_Name: "strLTyp",
            width: 93,
            height: 23,
            char_width: 8,
            • 3. Re: How do I keep original selection showing in drop down list
              You will need to save the selected value into a global variable and then
              re-apply to the field it in the initialize event of the dialog.
              On Sun, Apr 30, 2017 at 8:16 PM, sargums46564804 <forums_noreply@adobe.com>
