3 Replies Latest reply on May 1, 2017 10:50 AM by beh_gras_beh
    Validation script
    beh_gras_beh
      Dear people,
      I'm having problems with a piece of script what I am trying to implement in a form field.
      This is the code, only how can I apply this that the input is from the form field and the output automatically changes.
      function encode( str, prepend )
          var result = [];
          if ( prepend ) {
              result.push( str.charAt( 0 ) );
          result.push( encode.first( str ) );
          result.push( encode.second( str ) );
          return result.join( ' ' ).trim();
      encode.table = {
          A: [ 0,   1,   2,   3,   4,   5,   6,   7,   8,   9 ],
          B: [';', 'a', 's', 'd', 'f', 'g', 'h', 'j', 'k', 'l'],
          C: ['p', 'q', 'w', 'e', 'r', 't', 'y', 'u', 'i', 'o']
      encode.keys = [
          ['A', 'A', 'A', 'A', 'A', 'A'],
          ['A', 'A', 'B', 'A', 'B', 'B'],
          ['A', 'A', 'B', 'B', 'A', 'B'],
          ['A', 'A', 'B', 'B', 'B', 'A'],
          ['A', 'B', 'A', 'A', 'B', 'B'],
          ['A', 'B', 'B', 'A', 'A', 'B'],
          ['A', 'B', 'B', 'B', 'A', 'A'],
          ['A', 'B', 'A', 'B', 'A', 'B'],
          ['A', 'B', 'A', 'B', 'B', 'A'],
          ['A', 'B', 'B', 'A', 'B', 'A'],
      encode.first = function ( str ) {
          var key = encode.keys[ +str.charAt( 0 ) ];
          return str
              .substring( 1, 7 )
              .split( '' )
              .map(function ( number, index ) {
                  return encode.table[ key[ index ] ][ +number ];
              .join( '' )
      encode.second = function ( str ) {
          return str
              .substring( 7, 13 )
              .split( '' )
                  return encode.table.C[ +number ];
              .join( '' )
      encode('2230154678901', true) // 2 23;a5f yuiopq
        • 1. Re: Validation script
          JR_Boulay Adobe Community Professional
          Hi.
          What problems?
          What this script is expected to do?
          • 2. Re: Validation script
            beh_gras_beh Level 1
            I have created a font wich can be used to create an EAN-13 barcode which is a superset of the UPC-A barcode.
            How to use
            EAN-13 has 3 symbol sets A, B, and C. It looks like the following: *XXXXXX#CCCCCC*
            * start/end bar (as common for Code 39)
            # middle bar
            X a symbol of set A or B (see below)
            C a symbol of set C
            Symbol sets
            The symbol sets are placed on an international keyboard layout:
            Number row: 1234567890
            Middle character row: asdfghjkl;
            Top character row: qwertyuiop
            The first digit of an EAN-13 barcode does not directly correspond to a symbol. It determines which symbol set for the following 6 digits is to be used. The following listing shows the symbol set combinations for the starting digits:
            AABABB
            AABBAB
            AABBBA
            ABAABB
            ABBAAB
            ABBBAA
            ABABAB
            ABABBA
            ABBABA
            If the starting digit is 0, or if you want to encode a UPC-A, only use symbol set A.
            Examples
            The spaces are only inserted for clarity.
            EAN number → symbol set → What you type with the font
            2 012345 67890 3 → *AABBAB#CCCCCC* → *01sd4g#yuiope*
            2 230154 67890 1 → *AABBAB#CCCCCC* → *23;a5f#yuiopq*
            9 786789 12345 1 → *ABBABA#CCCCCC* → *7kh7k9#qwertq*
            9 789876 12345 7 → *ABBABA#CCCCCC* → *7kl8j6#qwertu*
            Only can I do this in a form field?
            • 3. Re: Validation script
              This works,
                  var result = [];
                  if ( prepend ) {
                  return result.join( '' ).trim();
              encode.table = {
              encode.keys = [
                  return str
                      .substring( 1, 7 )
                      .split( '' )
                      .join( '' ) + '#'
                  return str
                      .substring( 7, 13 )
                      .split( '' )
                      .join( '' )
              event.value = "*" + encode(event.value, false) + "*";
