When I want to save a file the contains a (imported) pdf file or layer, my programm gives a total error and shuts down.
The problem doesn't occur with any other filesorts; with jpg's, psd's or png's there are no problems.
I have update Elements (already had the latest version).
Can anyone help me to solve this problem?
Thank you
Please try clearing preferences once.
To do so, go to Edit > Preferences.
Click on Reset Preferences on next launch. Now re-launch Editor.
Anwesha
Thank you for your fact reply Anwesha.
Unfortunately it hasn´t solved my problem yet,
Best wishes
Mayka
Hi MCOVG,
Thanks for posting in Adobe forums.
I understand you are facing issue with the crash of Adobe Photoshop Elements 14.
Can we try the following steps:
- Open "Control Panel"
- Open "Programs & Features"
- Repair the following list of programs
* Microsoft Visual C++ 2012 Redistributable (x64)
* Microsoft Visual C++ 2012 Redistributable (x86)
* Microsoft Visual C++ 2013 Redistributable (x64)
* Microsoft Visual C++ 2013 Redistributable (x86)
* Microsoft Visual C++ 2015 Redistributable (x64)
* Microsoft Visual C++ 2015 Redistributable (x86)
- Restart your machine & check Adobe Photoshop Elements
If your issue doesn't resolve please provide your crash logs.
Regards
Dhananjay
I´ve tried that but it didn´t work. After that I deleted the complete Elements programm and reinstalled it. The reinstall worked well but the problem is still the same, as soon as I want to save a pdf file or a file with a pdf layer the programm shuts down immidiately.
I have saved my crash log but I can´t find how I can include it in this post. So I send you the text
Logboeknaam: Application
Bron: Application Error
Datum: 4-5-2017 8:13:34
Gebeurtenis-id:1000
Taakcategorie: (100)
Niveau: Fout
Trefwoorden: Klassiek
Gebruiker: n.v.t.
Computer: xxxxxxxxxxxx
Beschrijving:
Naam van toepassing met fout: PhotoshopElementsEditor.exe, versie: 14.0.0.0, tijdstempel: 0x55df8c21
Naam van module met fout: MSVCR120.dll, versie: 12.0.21005.1, tijdstempel: 0x524f83ff
Uitzonderingscode: 0xc0000409
Foutmarge: 0x0000000000074a30
Id van proces met fout: 0xdd4
Starttijd van toepassing met fout: 0x01d2c49d15c18017
Pad naar toepassing met fout: C:\Program Files\Adobe\Photoshop Elements 14\PhotoshopElementsEditor.exe
Pad naar module met fout: C:\WINDOWS\SYSTEM32\MSVCR120.dll
Rapport-id: 489ba112-ab6a-48b5-9450-47e0c57ce2fd
Volledige pakketnaam met fout:
Relatieve toepassings-id van pakket met fout:
Gebeurtenis-XML:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2017-05-04T06:13:34.396772400Z" />
<EventRecordID>46232</EventRecordID>
<Channel>Application</Channel>
<Computer>MaykaOvergaauw</Computer>
<Security />
</System>
<EventData>
<Data>PhotoshopElementsEditor.exe</Data>
<Data>14.0.0.0</Data>
<Data>55df8c21</Data>
<Data>MSVCR120.dll</Data>
<Data>12.0.21005.1</Data>
<Data>524f83ff</Data>
<Data>c0000409</Data>
<Data>0000000000074a30</Data>
<Data>dd4</Data>
<Data>01d2c49d15c18017</Data>
<Data>C:\Program Files\Adobe\Photoshop Elements 14\PhotoshopElementsEditor.exe</Data>
<Data>C:\WINDOWS\SYSTEM32\MSVCR120.dll</Data>
<Data>489ba112-ab6a-48b5-9450-47e0c57ce2fd</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
Hi MCOVG,
As suggested by dhananjays36801738 repair for Microsoft Visual C++ should fix the issue however if not then please try giving permission to the folder where you are saving your project.
Here is how you can give permission to that folder:
How do I change folder and file Permissions? - Microsoft Community
Regards,
Piyush
