3 Replies Latest reply on May 1, 2017 5:25 AM by terris86415680
    Photoshop 2017 cc templates
    joshe9791706 Level 1
      Downloaded Template
      I know it downloaded because in the upper right hand corner of the template is a blue circle with a check mark inside
      It is my understanding that the downloaded template should appear in Library
      The template is not in my library
      Any and all help is greatly appreciated.
        • 1. Re: Photoshop 2017 cc templates
          Trevor.Dennis Adobe Community Professional
          Hi Joshe
          Can you give us the link you sourced the template from?
          Does the file have an extension, and if yes, what is it?
          What browser did you use, and what is your operating system?
          • 2. Re: Photoshop 2017 cc templates
            Link was sourced by clicking new on smart page. New document opened that contains blank document presets and templates. I clicked on Textured Geometrics and created it.
            My operating system is macOS 10.12.4.
            Google is my browser.
            How can I tell if the file has an extension?
            • 3. Re: Photoshop 2017 cc templates
              terris86415680 Adobe Community Professional
              Hi there,
              yes templates should appear in the library panel but not necessarily in the library called 'My Library'
              When you download a template it appears with a blue check mark
              You know it has been saved to your hard disk because it shows up under the 'saved' tab
              If you want you can open it from there
              If you look at Libraries on the Adobe website you see all your current libraries. In the top right corner of the libraries panel select 'view on website'
              A browser will open. As you can see Stock Templates have a dedicated folder and don't go into the default 'My Library'.
              This can sometimes be a problem and you may have to 'Create a new library yourself. In the library panel called 'Stock Templates'
              It happened automatically for me, but I'm using Windows so a Mac maybe more obstinate. However you only need to do this once
              After that your templates should be visible in the library like below.
              Templates are just Psd files with a Psdt extension. In fact you can create your own template from a psd file by renaming it *.psdt. You can find them on your hard disk by doing a search on *.psdt, but Adobe have not been particularly helpful as they reside in hidden folders with GUID names and so you need to make those folders visible before you can see them. On Windows it's just a matter of making changes in folder options, but I think it's a little more involved on a Mac.
              To speed up a search on Windows jump to the 'AppData' section. Like below
              C:\Users\<profileName>\AppData\Roaming\Adobe\
              The Mac folders are arranged differently so one of our Mac users would need to tell you the precise location there.
