Using after effect cs6, I was trying to start my graduation work today. When I trying to put ai file, the warning came out like that. It was frist time that I've been ever seen.
I don't know why it's happens like that. My laptop is microsoft windows xp.
I want to know about why it happens and the solution about that!!
Please!!!!!!
I need to make my graduation work!!!!!!
Make sure the illustrator file is RGB color and not CMYK color.
Windows XP is REALLY old, even for CS6. Make sure the OS is running in 64 bit.
Although I made my ai file into RGB color already, it doesn't work....
Oh, my laptop is windows 10! I misunderstand. Then how should I work my after effect cs6 ?
If your operating system in Windows 10, you should double-check to make sure your version of AE CS6 is at least version 11.0.4. If it is not, you will need to update it.
I'm Sorry to ask question about my problem again...
How can I check my cs6's version and update it.......
I'm terribly sorry.
Updates start here and select product, read to see if you need to install updates in number order, or if the updates are cumulative for the individual product http://www.adobe.com/downloads/updates/
Help>About After Effects will show you the full version number.
Did you ever get your project done, 소희박? How did it go? Still need help? Let us know.
Kevin
