9 Replies Latest reply on May 3, 2017 9:28 AM by kglad
    I've got an error in my code and I don't understand code help?
    N2NavyXSeal2
      ADOBE ANIMATE
      I'm new to coding and I don't understand it. I'm using AS3 and i'm trying to make a pause and play button in my game so I typed in this code:
      yourButton.addEventListener(MouseEvent.CLICK, pauseGame);
      function pauseGame(e:MouseEvent):void{
           stage.frameRate = 0;
      yourOtherButton.addEventListener(MouseEvent.CLICK, resumeGame);
      function resumeGame(e:MouseEvent):void{
           stage.frameRate = 15;
      and it's giving me errors:
      M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 142, Column 81120: Access of undefined property yourButton.
      M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 142, Column 541120: Access of undefined property pauseGame.
      M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 147, Column 51120: Access of undefined property yourOtherButton.
      M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 147, Column 561120: Access of undefined property resumeGame.
      I don't know what this means...
      (the part that is in Bold is the code it has a problem with) The full code is:
      package{
          import flash.display.MovieClip;
          import flash.events.KeyboardEvent;
          import flash.ui.Keyboard;
          import flash.events.Event; //used for ENTER_FRAME event
        import flash.events.MouseEvent;
          public class Main extends MovieClip{
              //constants
              const gravity:Number = 1.5;            //gravity of the game
              const dist_btw_obstacles:Number = 300; //distance between two obstacles
              const ob_speed:Number = 16;             //speed of the obstacle
              const jump_force:Number = 15;          //force with which it jumps
              //variables
              var player:Player = new Player();
              var lastob:Obstacle = new Obstacle();  //varible to store the last obstacle in the obstacle array
              var obstacles:Array = new Array();     //an array to store all the obstacles
              var yspeed:Number = 0;                 //A variable representing the vertical speed of the bird
              var score:Number = 0;                  //A variable representing the score
              public function Main(){
                  init();
              function init():void {
                  //initialize all the variables
                  player = new Player();
                  lastob = new Obstacle();
                  obstacles = new Array();
                  yspeed = 0;
                  score = 0;
                  //add player to center of the stage the stage
                  player.x = stage.stageWidth/2;
                  player.y = stage.stageHeight/2;
                  addChild(player);
                  //create 3 obstacles ()
                  createObstacle();
                  createObstacle();
                  createObstacle();
                  //Add EnterFrame EventListeners (which is called every frame) and KeyBoard EventListeners
                  addEventListener(Event.ENTER_FRAME,onEnterFrameHandler);
                  stage.addEventListener(KeyboardEvent.KEY_UP, key_up);
              private function key_up(event:KeyboardEvent){
                  if(event.keyCode == Keyboard.SPACE){
                      //If space is pressed then make the bird
                      yspeed = -jump_force;
              function restart(){
                  if(contains(player))
                      removeChild(player);
                      for(var i:int = 0; i < obstacles.length; ++i){
                          if(contains(obstacles[i]) && obstacles[i] != null)
                          removeChild(obstacles[i]);
                          obstacles[i] = null;
                      obstacles.slice(0);
                      init();
              function onEnterFrameHandler(event:Event){
                  //update player
                  yspeed += gravity;
                  player.y += yspeed;
                  //restart if the player touches the ground
                  if(player.y + player.height/2 > stage.stageHeight){
                      restart();
                  //Don't allow the bird to go above the screen
                  if(player.y - player.height/2 < 0){
                      player.y = player.height/2;
                  //update obstacles
                  for(var i:int = 0;i<obstacles.length;++i){
                      updateObstacle(i);
                  //display the score
                  scoretxt.text = String(score);
              //This functions update the obstacle
              function updateObstacle(i:int){
                  var ob:Obstacle = obstacles[i];
                  if(ob == null)
                  return;
                  ob.x -= ob_speed;
                  if(ob.x < -ob.width){
                      //if an obstacle reaches left of the stage then change its position to the back of the last obstacle
                      changeObstacle(ob);
                  //If the bird hits an obstacle then restart the game
                  if(ob.hitTestPoint(player.x + player.width/2,player.y + player.height/2,true)
                     || ob.hitTestPoint(player.x + player.width/2,player.y - player.height/2,true)
                     || ob.hitTestPoint(player.x - player.width/2,player.y + player.height/2,true)
                     || ob.hitTestPoint(player.x - player.width/2,player.y - player.height/2,true)){
                      restart();
                  //If the bird got through the obstacle without hitting it then increase the score
                  if((player.x - player.width/2 > ob.x + ob.width/2) && !ob.covered){
                      ++score;
                      ob.covered = true;
              //This function changes the position of the obstacle such that it will be the last obstacle and it also randomizes its y position
              function changeObstacle(ob:Obstacle){
                  ob.x = lastob.x + dist_btw_obstacles;
                  ob.y = 100+Math.random()*(stage.stageHeight-200);
                  lastob = ob;
                  ob.covered = false;
              //this function creates an obstacle
              function createObstacle(){
                  var ob:Obstacle = new Obstacle();
                  if(lastob.x == 0)
                  ob.x = 800;
                  else
                  addChild(ob);
                  obstacles.push(ob);
                  lastob = ob;
      Message was edited by: JSM (Discussion successfully moved from The Lounge to Adobe Animate CC - General)
        • 1. Re: I've got an error in my code and I don't understand code help?
          try:
          package{
                  //constants
                  //variables
                      init();
                      yspeed = 0;
                      score = 0;
                      addChild(player);
                      createObstacle();
                      createObstacle();
                      createObstacle();
                  function restart(){
                          obstacles.slice(0);
                          init();
                      //update player
                      yspeed += gravity;
                      player.y += yspeed;
                          restart();
                      //update obstacles
                          updateObstacle(i);
                      //display the score
                      if(ob == null)
                      return;
                      ob.x -= ob_speed;
                          changeObstacle(ob);
                          restart();
                          ++score;
                          ob.covered = true;
                      lastob = ob;
                      ob.covered = false;
                      if(lastob.x == 0)
                      ob.x = 800;
                      else
                      addChild(ob);
                      obstacles.push(ob);
                      lastob = ob;
          • 2. Re: I've got an error in my code and I don't understand code help?
            N2NavyXSeal2 Level 1
            I tried the code and it got rid of two of the problems in it, but it still has two more problems.
            M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 48, Column 41120: Access of undefined property yourButton.
            M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 49, Column 51120: Access of undefined property yourOtherButton.
            • 3. Re: I've got an error in my code and I don't understand code help?
              then you didn't create those two objects.  i can see they're not created with code so they should be created on frame 1.
              • 4. Re: I've got an error in my code and I don't understand code help?
                I have created them as buttons and it started to work but now the buttons don't do anything.
                • 5. Re: I've got an error in my code and I don't understand code help?
                  what do you mean by, '... it started to work'?
                  • 6. Re: I've got an error in my code and I don't understand code help?
                    just.emma Level 4
                    You need to give the buttons instance names.
                    • 7. Re: I've got an error in my code and I don't understand code help?
                      The game now works but the buttons don't.
                      • 9. Re: I've got an error in my code and I don't understand code help?
                        use the trace function to debug.  eg, are your button listener functions called?
