5 Replies Latest reply on May 1, 2017 2:16 PM by ErichV
    Converting date field into three separtate, formatted fields
    ErichV Level 1
      Hello,
      I am trying to find a script that will convert a date field (XX/XX/XX) into three separate fields to populate the following text:
      In WITNESS WHEREOF, the respective parties thereto have executed this instrument this _____day of
      _____________, 20________.
      I am a novice at best with JavaScript and I have not been able to locate anything online to assist me with this problem.
      Can anyone out there help??
        • 1. Re: Converting date field into three separtate, formatted fields
          As the custom validation code of the text field you can enter something like this:
          if (event.value) {
              this.getField("Day").value = event.value.split("/")[0];
              this.getField("Month").value = event.value.split("/")[1];
              this.getField("Year").value = event.value.split("/")[2];
          } else this.resetForm(["Day", "Month", "Year"]);
          You'll probably need to adjust the field-names in the code to match those in your file...
          • 2. Re: Converting date field into three separtate, formatted fields
            We need to know what positions are the month, day, and year since there are some countries that use the "mm/dd/yy" format and others use the "dd/mm/yy" format.
            Also do you want the month spelled out and do you want to use the ordinal number of the day?
            • 3. Re: Converting date field into three separtate, formatted fields
              ErichV Level 1
              Great questions, I should have been more specific.  The date field is in the mm/dd/yy format.
              The month must be spelled out.
              And if possible, the date should appropriate suffix (e.g. 1st, 15th)
              • 4. Re: Converting date field into three separtate, formatted fields
                Assuming the input date field is named "Date" and the 3 output fields are "Day", "Month", and "Year", the following validation script for the "Date" field will populate the 3 output fields.
                // document level function;
                function ordinal(i) {
                purpose: convert inter to ordinal number;
                input: any integer;
                return: intieger and ordinal suffix;
                    var cOrdinal = "";
                    var sufixes = new Array("th", "st", "nd", "rd", "th", "th", "th", "th", "th", "th");
                    switch (i % 100) {
                    case 11:
                    case 12:
                    case 13:
                         cOrdinal = i + "th";
                    break;
                    default:
                        cOrdinal = i + sufixes[i % 10];
                     break;
                    } // end switch;
                    return cOrdinal;
                } // end of ordinal function;
                // end document level function
                // custom validation script;
                // can include above document level function;
                var cDate = "";
                var cMonth = "";
                var cYear = "";
                if(event.value != "") {
                cFormat = "mm/dd/yy"; // must be the same format as the field being validated;
                var oDate = util.scand(cFormat, event.value); // convert to date objec;
                // validate input date;
                if(oDate == null)
                  app.alert("Input date is not a valid date", 1, 0, "Entry Error");
                } else {
                  // date as ordinal number;
                  var cDate = ordinal(oDate.getDate());
                  // spelled out month;
                  var cMonth = util.printd("mmmm", oDate);
                  // two digit year;
                  var cYear = util.printd("yy", oDate);
                } // end date validation;
                } // end target value not null;
                // set field values;
                this.getField("Day").value = cDate;
                this.getField("Month").value = cMonth;
                this.getField("Year").value = cYear;
                // end validation script;
                The above code will also validate the inputted date and clear the output fields if the input field is blank.
                • 5. Re: Converting date field into three separtate, formatted fields
                  ErichV Level 1
                  You have made my day!  Thank you SO much!!  Works like a charm!
