0 Replies Latest reply on Dec 8, 2008 2:27 AM by sielco
    Call JSFL from Flex Air application
    sielco
      I have a Flex Air application that converts old style flash text var txt files into XML. As part of the process it creates a jsfl file that when run will automate through older FLAs and upgrade them with changes required.
      My question is this. Using the command fl.runScript(locationOfJSFLscript) in flash, it will automatically call the script and execute it. How do I do the same in Flex? i.e. I have a button in the application. I press it and it sends the call to run the script.
      Thank you
