4 Replies Latest reply on May 2, 2017 1:16 PM by stephanier97973891
    Can I connect a Drop Down Field w/ a Text Field?
    stephanier97973891
      I want to set up the drop down field to where when the item is chosen the price for that item shows up in a different text field.
      So if they pick Tin from the "Material Options" drop down field the price $.04 will show up in the "Price" text field.
      What do I need to do to set that up?  I was thinking JavaScript but do not know how to set it up.  Can someone please help me w/ the right code?
      Also, after the price shows up in the Price text field, can that field still be calculated w/ a different text field?
        • 1. Re: Can I connect a Drop Down Field w/ a Text Field?
          Joel_Geraci Adobe Community Professional
          Add the following code to the price field calculation script...
          event.value = this.getField("Material Options").value;
          I'm not sure what you are asking in the last sentence. "Price" can, of course, be used as the input to another calculation if that's what you meant. But it reads as though you want "Price" to be populated but also be calculated after a price has been selected. you can only have one calculation per field so if you wanted the value of "Price" to be calculated based on "Material Options" and something else, you'd need to put that in the calculation script as well... for example if "Price" is "Material Options" multiplied by the "Quantity", your calculation for "Price" would be...
          event.value = this.getField("Material Options").value * this.getField("Quantity").value
          • 2. Re: Can I connect a Drop Down Field w/ a Text Field?
            stephanier97973891 Level 1
            I tried to place the first script event.value = this.getField("Material
            Options").value; but it only works if the Formats are the same in both
            fields.  The drop down field has words like, Tin, Short Iron, Long Iron.
            I’m wanting the “Price” field to be a number.  Can they still connect?  Or
            do I have to come up with a different solution to connect them?
            For my last sentence:  this is how I have it set up on my PDF.  The drop
            down list is the “Material Options”.  When the person picks the material
            (Tin, Short Iron, Long Iron, etc.), I want the particular price for that
            item to show up in the “Price”  field.  Then they’ll enter the weight and
            I’ll have ‘Price x Weight’ in the “Total” field.
            Material Options
            Price
            Weight
            Total
            On another note, I found a different post about connecting two different
            drop down fields.  I tried the script and it worked how I wanted it to but,
            I couldn’t do my multiplication equation in the “Total” field w/ a drop
            down list #.  Do you have any suggestions?
            Thank you!
            Stephanie Rivera
            Engineering Assistant
            • 3. Re: Can I connect a Drop Down Field w/ a Text Field?
              Dropdowns have an item name and an export value. The item name is what appears in the list. The export value is what gets used in calculations. Just add your item names and set the value you want to appear in the Price field for that item to be the export value.
              The calculation for your total field becomes...
              event.value = this.getField("Material Options").value * this.getField("Weight").value
              Your "Price" field is basically just for show.
              • 4. Re: Can I connect a Drop Down Field w/ a Text Field?
                Thank you!  It works perfectly now!
                Stephanie Rivera
