I want to use a character style sheet in TAB Leader. How is it possible? Should I use GREP or something else?
Please help.
Thank you in Advance!
In GREP you can use this: \t and do what do you want
You want to apply a character style to the tab? You could do this with a nested style "through one tab".
Thank you for your answer@dhafirp16891848
. I had resolved it already but this was the correct answer I was looking for. Thank you once again.
Welcome
Are you asking how to change the leader dots automatically? In the example below, I used a character style to target just the leaders:
If that is what you are after, you can just nest character styles in a paragraph style.
For the text below, I have a ¶ style called TOC assigned the the three lines. In Drop Caps and Nested Styles, I created the first nested style to assign [None] up to 1 tab (so that the words in front are unaffected) and added a second nested style to assign the Character tag called Leaders (which simply changes the color of the text) through 1 tab.
