Hello
I was sent a .MOV file which I have converted to an MP4. When I open that MP4 clip on my desktop (Windows 10), I can hear the audio. But when I open Premier Elements 11 | Add Media, the video of that movie clip plays but there is no audio: there are no green layers on the Audio 1 track on the Timeline and I am hoping to correct that, please?
Other audio on the same Timeline in this same project play fine.
Steve
Premiere Elements should be able to work with that file as is, assuming you've got Quicktime 7 installed on your system. What happens when you add this MOV to your project?
It may help to manually set up your project by starting a new project and, on the New Project option screen, clicking Settings. On the settings panel that appears, select Flip/Flip Mino HD and Ultra HD 29_97p.
This is one of the reasons it's dangerous to convert a file, unless you absolutely know what you're doing. You may well convert the file to a format that is less compatible than what you originally had.
Open the MP4 in the free download MediaInfo, open the View in Tree format and cut and paste the information to this forum. We'll be better able to make a recommendation once we know what that MP4 is made of.
Although, as I said, there was likely no reason to convert the MOV in the first place. Do you know what the specs of the MOV are? Did it come directly from a camcorder or was it too produced by a piece of software?
(Note that version 11 will require you to install Quicktime 7 in order for you to edit an MOV -- and some MP4s -- in Premiere Elements.)
Hello Steve
Thanks for your reply and link - I have now downloaded QuickTime.
I converted the movie clip from MOV to MP4 because Prem Elements would not add the MOV files and, as I mentioned, did not play the MP4 audio. I got around that, eventually, by opening Windows Movie Maker, importing the MP4 file I had originally converted from the MOVm format, and saving it as a WMV file. I then imported that to the Timeline in Prem Elements and both video and audio on the clip play just fine, though I know this is not the ideal way of doing things.
I went to Tree View in MediaInfo bur couldn't copy and paste, so went to Text View instead. This is what it shows:
General
Complete name : C:\Users\Steve\Desktop\Mum_Final\Dedications\IMG_2417.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 0000.00 (qt )
File size : 23.9 MiB
Duration : 30s 882ms
Overall bit rate : 6 501 Kbps
Encoded date : UTC 2017-04-26 10:03:23
Tagged date : UTC 2017-04-26 10:03:54
Writing library : Apple QuickTime
com.apple.quicktime.location.ISO6709 : +53.4682-002.6751+050.131/
com.apple.quicktime.make : Apple
com.apple.quicktime.model : iPhone 5s
com.apple.quicktime.software : 10.3.1
com.apple.quicktime.creationdate : 2017-04-26T11:03:23+0100
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 6 398 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Rotation : 90°
Frame rate mode : Variable
Frame rate : 29.970 (29970/1000) fps
Minimum frame rate : 28.571 fps
Maximum frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.232
Stream size : 23.6 MiB (98%)
Title : Core Media Video
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 30s 880ms
Source duration : 30s 952ms
Bit rate mode : Constant
Bit rate : 64.0 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 44.1 KHz
Frame rate : 43.066 fps (1024 spf)
Compression mode : Lossy
Stream size : 244 KiB (1%)
Source stream size : 245 KiB (1%)
Title : Core Media Audio
Other #1
Type : meta
Bit rate mode : VBR
Other #2
Type : meta
Bit rate mode : CBR
The clip was filmed on a Mac phone.
Thanks again for your time.
Steve
Hello Steve
Thanks again.
That .MOV clip plays fine now since I have installed QuickTime (I didn't realise that software was necessary).
There is a difficulty saving it as HD because the project will go on a DVD and the person who this is for (my mum) doesn't have an HD TV/Playerm so I am working on it now as a .MP4 file, PAL 25 frames per/sec, widescreen, 720px x 576px. That seems to be playing fine at the moment on the Timeline.
After these 30 minutes of different clips which all now have the same dimensions and audio levels, I am hoping the second 'part' of the same DVD will comprise a slideshow of still photos accompanied by a soundtrack.
Thanks again.
Steve
