4 Replies Latest reply on May 10, 2017 8:31 AM by Mindy Asks
    Validation for max amounts and numerical increments
    Mindy Asks
      Hi there - I am creating a form that has two fields with unique validation requirements:
      Field 1 - It must be an increment of $10,000 and cannot exceed $1,000,000.
      Field 2 - It must be an increment of $10,000, and cannot exceed both Field 1 and $500,000.
      Can anyone help with how I would write the validation script for these two fields? Please and many thanks. Mindy
        • 1. Re: Validation for max amounts and numerical increments
          George_Johnson MVP & Adobe Community Professional
          Can you explain what you mean by "increment of $10,000"? If you mean a multiple of $10,000, (e.g., 10,000, 20,000, 30,000,..., 1,000,000), what do you want to happen if the user enters a value like 123,456?
          If the user enters a value in Field 2, what should happen if Field 1 is blank?
          • 2. Re: Validation for max amounts and numerical increments
            Mindy Asks Level 1
            Hi George! Thanks so much for the quick response and my apologies for not being more clear (this is the first time I've posted a question to a forum).  To answer your questions:
            1) Yes, I mean that the user should only be able to input a number in multiples of $10,000.  If the user enters a value like $123,456 or enters a number greater than $1,000,000, I would like them to receive an error message like "Entry not valid.  Your election must be a multiple of $10,000 up to a maximum of $1,000,000."
            2) If the user enters a value in Field 2 without an entry (blank) in Field 1, I would like the validation to treat Field 1 as if were "0", causing the user to receive an error message like "Entry not valid. Your election must be a multiple of $10,000 up to a maximum of $500,000 and cannot exceed your Field 1 election."  I would imagine that this same error message can be applied if the user makes an invalid entry for any of the rules.
            Does this help?
            • 3. Re: Validation for max amounts and numerical increments
              Here's a custom validation script you can use for FIeld 1. Just tailor the error messages to suit you needs:
              // Custom Validate script for Field 1
              (function () {
                  // Do nothing if value is blank
                  if (!event.value) {
                      return;
                  // Convert entry to a number
                  var nVal = +event.value;
                  // Deal with negative/zero values
                  if (nVal <= 0) {
                      app.alert("Please enter a positive value.", 3);
                      // Reject entry
                      event.rc = false;
                      return;
                  // Deal with a value greater than 1,000,000
                  if (nVal > 1000000) {
                      app.alert("Please enter a value equal to or less than 1,000,000.", 3);
                      event.rc = false;
                      return;
                  // Deal with a value that's not a multiple of 10,000
                  if (nVal % 10000) {
                      app.alert("Please enter a value that is a multiple of 10,000.", 3);
                      event.rc = false;
                      return;
                  // Everything is OK, so nothing more to do
              For Field 2, the script could be modified to something like:
              // Custom Validate script for Field 2
              (function () {
                  if (!event.value) {
                      return;
                  // Get the value of Field 1, as a string
                  var s1 = getField("Field 1").valueAsString;
                  // Reject entry if field 1 is blank
                  if (!s1) {
                      app.alert("Please first enter a value in Field 1", 3);
                      event.rc = false;
                      return;
                  // Convert Field 1 value to a number
                  var n1 = +s1;
                  // Deal with a value greater than Field 1 value
                  if (nVal > n1) {
                      app.alert("Please enter a value less than or equal to Field 1", 3);
                      event.rc = false;
                      return;
                  if (nVal <= 0) {
                      event.rc = false;
                      return;
                  // Deal with a value greater than 500,000
                  if (nVal > 500000) {
                      app.alert("Please enter a value equal to or less than 500,000.", 3);
                      event.rc = false;
                      return;
                  if (nVal % 10000) {
                      event.rc = false;
                      return;
              • 4. Re: Validation for max amounts and numerical increments
                Mindy Asks Level 1
                Sorry for the delay in responding, George. I got distracted with other project at work and just had time to revisit this.  Good news... it worked perfectly, THANKS SO MUCH!
