6 Replies Latest reply on Jul 16, 2017 7:12 AM by witkacy
    Select and Mask vs. Refine Edge keyboard operation
    witkacy Level 1
      Hello,
      I am facing a move from CS6 to CC at work. I've looked into an important part of my day to day which is Refine Edge known as Select and Mask workspace in CC. I would love to embrace the change (if only to deny the thought that I'm really to old for changes).
      I can retrain my muscle memory for the new preview shortcuts, I think. Nevertheless, I have encountered problems I can't seem to be able to overcome:
      1. Is there a keyboard shortcut to focus the first entry field in the Select and Mask workspace?
      2. Relatedly, why isn't there an Auto-Select Parameter option in Select and Mask? Am I missing something?
      3. There is a way to get to the old Refine Edge UI (which I would be forced to go back to if pts. 1-2 can't be resolved) by holding a Shift key while selecting Select and Mask from the Select menu. Is there a way to assign a keyboard shortcut to evoke Refine Edge without resorting to using a mouse (Shift+Cmd[Ctrl]+Alt does not work)?
      Not being able to use the keyboard slows me down too much.
      Thank you.
      Regards
      m.
        • 1. Re: Select and Mask vs. Refine Edge keyboard operation
          Sahil.Chawla Adobe Employee
          Hi Witkacy,
          You can still access the old Refine edge feature in Photoshop CC 2017.
          1. Make a selection.
          2. Click on Select on the top menu.
          3. Hold down the shift key on your keyboard and click on Select & Mask and you'll be able to use Refine Edge.
          Regards,
          Sahil
          • 2. Re: Select and Mask vs. Refine Edge keyboard operation
            witkacy Level 1
            Hi, Sahil,
            Thank you for your response. As noted in my pt. 3, I was already aware of a way to get to the old Refine Edge using a mouse and shift.
            What I would like to do is to get to it using a keyboard shortcut alone. I need this, because the new Select & Mask workspace slows me down too much as I cannot operate it with just a keyboard easily (see pts. 1–2).
            Thank you.
            Regards
            m.
            • 3. Re: Select and Mask vs. Refine Edge keyboard operation
              Trevor.Dennis Adobe Community Professional
              So just make one.  Are there functions you never use, and from which you could steal the shortcut?  Even iv you use absolutely everything, it won't be on an everyday basis.  CC2017 allows us to customise the Toolbar, and we are able to save custom Toolbars along with custom shortcuts and menus.
              So what I do is double duty a few shortcuts with my most used workspace, and switch back to Essentials when I need the default shortcuts.  I do this with a single key using the extra keys on a gaming keyboard.  Mine is a Logitech G910 which has 9 G keys that can have three banks of shortcuts (the pink keys in the image below).  Note you can change key colour individually, and this is program context sensitive.  I don't need the colours for Photoshop, but it is super handy for Sketchup where I can never remember which cursor key selects which axis.
              Regular poster JJ Mack takes this step further and has one of these:
              • 4. Re: Select and Mask vs. Refine Edge keyboard operation
                davescm Adobe Community Professional
                Hi
                On Windows Alt S Shift+K works to get the old refine edge . But I don't think that Alt method of steering through menus works on a Mac
                Dave
                • 5. Re: Select and Mask vs. Refine Edge keyboard operation
                  Conrad C Adobe Community Professional & MVP
                  I ran some quick tests on a Mac, and it looks like as long as you define a Select and Mask shortcut that includes the Shift key, Refine Edge will come up. Including simply adding the Shift key to the existing shortcut. The shortcut in this screen shot opens Refine Edge.
                  Not exactly the same way, but it can be done. On the Mac in System Preferences, there’s a user-configurable system keyboard shortcut, Move Focus to the Menu Bar, that lets you navigate menus with the keyboard.
                  Once you press that shortcut, you can select menus and commands using a type-ahead feature. To open Refine Edge this way:
                  1. Press the Move Focus to the Menu Bar shortcut (Control+F2 by default).
                  2. Type "s". This selects the Select menu.
                  3. Type "se". This selects the Select and Mask command on the Select menu.
                  4. Hold Shift while pressing Return or spacebar. This opens the Select and Mask command with the Shift key, opening Refine Edge.
                  In practical working terms this means you'd type "Control+F2 s se Shift-Return" as the equivalent of Alt-typing the menu and command in Windows.
                  But it's a lot faster to simply redefine the Select and Mask keyboard shortcut in Photoshop so that it includes the Shift key, because that's just one shortcut to press.
                  • 6. Re: Select and Mask vs. Refine Edge keyboard operation
                    witkacy Level 1
                    Oh, amazing! Thank you, I don’t know how I have missed that!
                    Trevor.Dennis, thanks, I’m aware I can modify shortcuts and save them (incl. as a part of a Workspace). But I can’t see a way to focus the editing fields in Select & Mask workspace using a keyboard (as they are by default in Refine Edge). Also, Auto-select Parameter is missing from Select & Mask and Shift+Enter disastrously commits the changes (it focuses the first editing field in palettes).
                    I need that because I’m used to blazing-fast operations in Refine Edge when touching a mouse (or a pen) would slow me down considerably.
                    Thanks to Conrad C’s workaround, I can maintain speed by using an old interface. Hopefully, before access to legacy tool is removed, these new workspace UIs gain Auto-Select Parameter ;-)
                    Regards
                    m.
