• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Numbered Lists - Two Levels on One Line
Guide ,
May 03, 2017 May 03, 2017
Hi all.
I have a multilevel list to format, where in some cases there need to be two levels on one line. See screenshot:
Number 5 is fine, as the text on first line is all Level 1. But 6 is numbered (Level 1) and goes straight into an alphabetical list (Level 2). I've put a return in the example so I could still apply the Level 2 Paragraph Style, but it really needs to knocked up a line and be separated by a tab. Is there a way to achieve this while keeping it a properly formatted list using Paragraph Styles?
Hopefully this explains it, but let me know if it doesn't!
Thanks.
Views
887
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guide , May 03, 2017 May 03, 2017
well, in this case you can make only Level 1Schermata 2017-05-03 alle 15.35.14.png
with Leading 0 and baseline shift equal with leading of Level 2
Votes
Translate
Translate
Guide ,
you can do it but you have to made one paragraph style for level 2 with leading 0 (and, of course, without space before)
Votes
Translate
Translate
Report
Report
Guide ,
Thanks, and nice try, but that won't work if there's more that one line in the paragraph.
Votes
Translate
Translate
Report
Report
Guide ,
If only InDesign let us apply negative paragraph spacing...
Votes
Translate
Translate
Report
Report
Guide ,
Votes
Translate
Translate
Report
Report
Advisor ,
Interesting solution...
Votes
Translate
Translate
Report
Report
Advisor ,
I guess the only other trouble with this is that it doesn't contain the formatting within just a couple of paragraph styles...
You would need maybe 6 paragraph styles just for each version to be applied within the list... Which is a shame.
Votes
Translate
Translate
Report
Report
Guide ,
Nailed it! Thanks for that... I should have thought of that, really.
Votes
Translate
Translate
Report
Report
Guide ,
(a) is Level 2
(b) and (c) are Level 2bis.
Votes
Translate
Translate
Report
Report
Advisor ,
Scratch my previous comments.. premio_oscar​ answer is correct.
Baseline shift on a secondary or alternative level 2 paragraph style is the way to achieve this!
Votes
Translate
Translate
Report
Report
Guide ,
LATEST
It's actually an alternative Level 1 that works, as the that paragraph always has only one line.
Votes
Translate
Translate
Report
Report
