8 Replies Latest reply on May 31, 2017 5:07 AM by olegl12198859
    photoshop cc 2017  very slow in startup  :(
    Hemazone Level 1
      Hi
      i had a photoshop CC (14.0)  ,  it was take only  6: 7  seconds  to start ,
      Adobe Photoshop
      but after i installed   Version: 2017.1.0 ( lastest version )   it takes more than  1min and 10 seconds !!!!!!
      and thats happen with the prev. version too
      and however there is no 3rd pary plugins and  its a fresh install   it takes alot of time in splash screen on ( scanning for plug-ins) line
      please help me
        • 1. Re: photoshop cc 2017  very slow in startup  :(
          Akash Sharma Adobe Employee
          Hi Hemazone,
          We just released Photoshop CC 2017.1.1 with bug fixes and performance improvements. Please update to the latest version and let us know if that helps.
          Also, skip loading plugins while you launch Photoshop to see if that works.To do so :-
          • Close Photoshop.
          • Hold down the Shift key and launch Photoshop. A dialogue appears during the launch that reads “Skip loading optional and third-party plug-ins?” Select "Yes".
          Skip loading dialog box
          Akash
          • 2. Re: photoshop cc 2017  very slow in startup  :(
            You give us little to go on.  With your subscription you can install CS6, CC, Cc 2014, CC 2015, CC 2015.5 and CC 2017.  I use CC 2014.  We do not know anything about what your environment
            Supply pertinent information for quicker answers
            • The more information you supply about your situation, the better equipped other community members will be to answer. Consider including the following in your question:
            • Adobe product and version number
            • Operating system and version number
            • The full text of any error message(s)
            • What you were doing when the problem occurred
            • Screenshots of the problem
            • Computer hardware, such as CPU; GPU; amount of RAM; etc.
            • 3. Re: photoshop cc 2017  very slow in startup  :(
              Zuriat
              You should check on your computer specification as CC 2017 really need a powerful hardware. Otherwise, your startup will take longer.
              • 4. Re: photoshop cc 2017  very slow in startup  :(
                Hemazone Level 1
                thank you for your replay
                this is my system  info
                i hope its  enough
                Adobe Photoshop Version: 2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877  x64
                Number of Launches: 2
                Version: 10 or greater
                System architecture: Intel CPU Family:6, Model:10, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX
                Physical processor count: 4
                Processor speed: 3093 MHz
                Built-in memory: 8150 MB
                Free memory: 4120 MB
                Memory available to Photoshop: 6992 MB
                Memory used by Photoshop: 70 %
                History Thumbnails: Enabled.
                Touch Bar: Enabled.
                Alias Layers: Disabled.
                Modifier Palette: Enabled.
                Highbeam: Enabled.
                Image tile size: 1024K
                Image cache levels: 4
                Font Preview: Medium
                TextComposer: Latin
                Display: 1
                Display Bounds: top=0, left=0, bottom=900, right=1440
                OpenGL Drawing: Enabled.
                OpenGL Allow Old GPUs: Not Detected.
                OpenGL Drawing Mode: Advanced
                OpenGL Allow Normal Mode: True.
                OpenGL Allow Advanced Mode: True.
                AIFCoreInitialized=1
                AIFOGLInitialized=1
                OGLContextCreated=1
                NumGLGPUs=1
                NumNativeGPUs=0
                glgpu[0].GLVersion="3.3"
                glgpu[0].IsIntegratedGLGPU=0
                glgpu[0].GLMemoryMB=1024
                glgpu[0].GLName="NVIDIA GeForce GT 220 "
                glgpu[0].GLVendor="NVIDIA Corporation"
                glgpu[0].GLVendorID=4318
                glgpu[0].GLDriverVersion="21.21.13.4201"
                glgpu[0].GLRectTextureSize=8192
                glgpu[0].GLRenderer="GeForce GT 220/PCIe/SSE2"
                glgpu[0].GLRendererID=2592
                glgpu[0].HasGLNPOTSupport=1
                glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
                glgpu[0].GLDriverDate="20161114000000.000000-000"
                glgpu[0].CanCompileProgramGLSL=1
                glgpu[0].GLFrameBufferOK=1
                glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="3.30 NVIDIA via Cg compiler"
                glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[96]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
                glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[60]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                License Type: Tryout Version
                Serial number: Tryout Version
                GUIDBucket:
                  bucket: 73
                  test: control
                Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
                Temporary file path: C:\Users\Colonel\AppData\Local\Temp\
                Photoshop scratch has async I/O enabled
                Scratch volume(s):
                  Startup, 297.5G, 121.7G free
                Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
                Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
                Installed components:
                   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                   ACE.dll   ACE 2017/01/26-01:10:02   79.579975   79.579975
                   AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
                   AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
                   AdobeOwl.dll   Adobe Owl   5.2.11
                   AdobePDFL.dll   PDFL 2016/08/10-16:53:20   79.195992   79.195992
                   AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
                   AdobeSVGAGM.dll   AdobeSVGAGM   79.579975   79.579975
                   AdobeXMP.dll   Adobe XMP Core 2016/09/14-01:09:01   79.159824   79.159824
                   AdobeXMPFiles.dll   Adobe XMP Files 2016/09/14-01:09:01   79.159824   79.159824
                   AdobeXMPScript.dll   Adobe XMP Script 2016/09/14-01:09:01   79.159824   79.159824
                   adobe_caps.dll   Adobe CAPS   10,0,0,6
                   AGM.dll   AGM 2017/01/26-01:10:02   79.579975   79.579975
                   ahclient.dll    AdobeHelp Dynamic Link Library   2.2.0.1
                   AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
                   amtlib.dll   AMTLib (64 Bit)   10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7)   1.000000
                   ARE.dll   ARE 2017/01/26-01:10:02   79.579975   79.579975
                   AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
                   AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                   Bib.dll   BIB 2017/01/26-01:10:02   79.579975   79.579975
                   BIBUtils.dll   BIBUtils 2017/01/26-01:10:02   79.579975   79.579975
                   boost_date_time.dll   photoshopdva   10.0.0
                   boost_signals.dll   photoshopdva   10.0.0
                   boost_system.dll   photoshopdva   10.0.0
                   boost_threads.dll   photoshopdva   10.0.0
                   cg.dll   NVIDIA Cg Runtime   3.0.00007
                   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                   CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
                   CoolType.dll   CoolType 2017/01/26-01:10:02   79.579975   79.579975
                   dnssd.dll   Bonjour   3,0,0,2
                   dvaaudiodevice.dll   photoshopdva   10.0.0
                   dvacore.dll   photoshopdva   10.0.0
                   dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
                   dvamarshal.dll   photoshopdva   10.0.0
                   dvamediatypes.dll   photoshopdva   10.0.0
                   dvametadata.dll   photoshopdva   10.0.0
                   dvametadataapi.dll   photoshopdva   10.0.0
                   dvametadataui.dll   photoshopdva   10.0.0
                   dvaplayer.dll   photoshopdva   10.0.0
                   dvatransport.dll   photoshopdva   10.0.0
                   dvaui.dll   photoshopdva   10.0.0
                   dvaunittesting.dll   photoshopdva   10.0.0
                   dynamiclink.dll   photoshopdva   10.0.0
                   ExtendScript.dll   ExtendScript 2016/12/13-13:10:33   80.1089815   80.1089815
                   icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                   icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                   icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                   igestep30.dll   IGES Reader   9.3.0.113
                   imslib.dll   IMSLib DLL   10.0.0.11
                   JP2KLib.dll   JP2KLib 2016/05/26-01:08:58   79.262945   79.262945
                   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                   libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                   libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                   LogSession.dll   LogSession   7.4.1.60.45263
                   mediacoreif.dll   photoshopdva   10.0.0
                   MPS.dll   MPS 2016/09/14-15:20:26   79.577269   79.577269
                   pdfsettings.dll   Adobe PDFSettings   1.04
                   Photoshop.dll   Adobe Photoshop CC 2017   18.1.0
                   Plugin.dll   Adobe Photoshop CC 2017   18.1.0
                   PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   7.0.0
                   PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   7.0.0.67
                   PSArt.dll   Adobe Photoshop CC 2017   18.1.0
                   PSViews.dll   Adobe Photoshop CC 2017   18.1.0
                   SCCore.dll   ScCore 2016/12/13-13:10:33   80.1089815   80.1089815
                   SVGRE.dll   SVGRE   79.579975   79.579975
                   svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                   tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                   TfFontMgr.dll   FontMgr   9.3.0.113
                   TfKernel.dll   Kernel   9.3.0.113
                   TFKGEOM.dll   Kernel Geom   9.3.0.113
                   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                   updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
                   VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
                   VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
                   WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
                   wu3d.dll   U3D Writer   9.3.0.113
                Required plug-ins:
                   3D Studio 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
                   Accented Edges 18.1.0 - from the file “Filter Gallery.8bf”
                   Adaptive Wide Angle 18.1.0 - from the file “Adaptive Wide Angle.8bf”
                   Angled Strokes 18.1.0 - from the file “Filter Gallery.8bf”
                   Average 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Average.8bf”
                   Bas Relief 18.1.0 - from the file “Filter Gallery.8bf”
                   BMP 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Camera Raw 9.10 - from the file “Camera Raw.8bi”
                   Camera Raw Filter 9.10 - from the file “Camera Raw.8bi”
                   Chalk && Charcoal 18.1.0 - from the file “Filter Gallery.8bf”
                   Chrome 18.1.0 - from the file “Filter Gallery.8bf”
                   Cineon 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Cineon.8bi”
                   Clouds 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Clouds.8bf”
                   Collada 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
                   Color Halftone 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Colored Pencil 18.1.0 - from the file “Filter Gallery.8bf”
                   CompuServe GIF 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Conté Crayon 18.1.0 - from the file “Filter Gallery.8bf”
                   Craquelure 18.1.0 - from the file “Filter Gallery.8bf”
                   Crop and Straighten Photos 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “CropPhotosAuto.8li”
                   Crop and Straighten Photos Filter 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Crosshatch 18.1.0 - from the file “Filter Gallery.8bf”
                   Crystallize 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Cutout 18.1.0 - from the file “Filter Gallery.8bf”
                   Dark Strokes 18.1.0 - from the file “Filter Gallery.8bf”
                   De-Interlace 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Dicom 18.1.0 - from the file “Dicom.8bi”
                   Difference Clouds 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Clouds.8bf”
                   Diffuse Glow 18.1.0 - from the file “Filter Gallery.8bf”
                   Displace 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Dry Brush 18.1.0 - from the file “Filter Gallery.8bf”
                   Eazel Acquire 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “EazelAcquire.8ba”
                   Entropy 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
                   Export Color Lookup Tables 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Export3DLUT.8be”
                   Extrude 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   FastCore Routines 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “FastCore.8bx”
                   Fibers 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Film Grain 18.1.0 - from the file “Filter Gallery.8bf”
                   Filter Gallery 18.1.0 - from the file “Filter Gallery.8bf”
                   Flash 3D 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
                   Fresco 18.1.0 - from the file “Filter Gallery.8bf”
                   Glass 18.1.0 - from the file “Filter Gallery.8bf”
                   Glowing Edges 18.1.0 - from the file “Filter Gallery.8bf”
                   Google Earth 4 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
                   Graphic Pen 18.1.0 - from the file “Filter Gallery.8bf”
                   Halftone Pattern 18.1.0 - from the file “Filter Gallery.8bf”
                   HDRMergeUI 18.1.0 - from the file “HDRMergeUI.8bf”
                   HSB/HSL 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   IFF Format 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   IGES 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
                   Ink Outlines 18.1.0 - from the file “Filter Gallery.8bf”
                   JPEG 2000 18.1.0 - from the file “JPEG2000.8bi”
                   Kurtosis 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
                   Lens Blur 18.1.0 - from the file “Lens Blur.8bf”
                   Lens Correction 18.1.0 - from the file “Lens Correction.8bf”
                   Lens Flare 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Liquify 18.1.0 - from the file “Liquify.8bf”
                   Matlab Operation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “ChannelPort.8bf”
                   Maximum 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
                   Mean 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
                   Measurement Core 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “MeasurementCore.8me”
                   Median 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
                   Mezzotint 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Minimum 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
                   MMXCore Routines 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “MMXCore.8bx”
                   Mosaic Tiles 18.1.0 - from the file “Filter Gallery.8bf”
                   Multiprocessor Support 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “MultiProcessor Support.8bx”
                   Neon Glow 18.1.0 - from the file “Filter Gallery.8bf”
                   Note Paper 18.1.0 - from the file “Filter Gallery.8bf”
                   NTSC Colors 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “NTSC Colors.8bf”
                   Ocean Ripple 18.1.0 - from the file “Filter Gallery.8bf”
                   OpenEXR 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Paint Daubs 18.1.0 - from the file “Filter Gallery.8bf”
                   Palette Knife 18.1.0 - from the file “Filter Gallery.8bf”
                   Patchwork 18.1.0 - from the file “Filter Gallery.8bf”
                   Paths to Illustrator 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   PCX 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “PCX.8bi”
                   Photocopy 18.1.0 - from the file “Filter Gallery.8bf”
                   Photoshop 3D Engine 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Photoshop3DEngine.8bi”
                   Photoshop Touch 14.0 - from the file “PSDX.8bi”
                   Picture Package Filter 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “ChannelPort.8bf”
                   Pinch 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Pixar 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Pixar.8bi”
                   Plaster 18.1.0 - from the file “Filter Gallery.8bf”
                   Plastic Wrap 18.1.0 - from the file “Filter Gallery.8bf”
                   PLY 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
                   PNG 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Pointillize 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Polar Coordinates 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Portable Bit Map 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “PBM.8bi”
                   Poster Edges 18.1.0 - from the file “Filter Gallery.8bf”
                   PRC 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
                   Radial Blur 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Radiance 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Radiance.8bi”
                   Range 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
                   Render Color Lookup Grid 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Export3DLUT.8be”
                   Reticulation 18.1.0 - from the file “Filter Gallery.8bf”
                   Ripple 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Rough Pastels 18.1.0 - from the file “Filter Gallery.8bf”
                   Save for Web 18.1.0 - from the file “Save for Web.8be”
                   ScriptingSupport 18.1.0 - from the file “ScriptingSupport.8li”
                   Shake Reduction 18.1.0 - from the file “Shake Reduction.8bf”
                   Shear 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Skewness 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
                   Smart Blur 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Smudge Stick 18.1.0 - from the file “Filter Gallery.8bf”
                   Solarize 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Solarize.8bf”
                   Spaces 18.1.0 - from the file “Spaces.8li”
                   Spatter 18.1.0 - from the file “Filter Gallery.8bf”
                   Spherize 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Sponge 18.1.0 - from the file “Filter Gallery.8bf”
                   Sprayed Strokes 18.1.0 - from the file “Filter Gallery.8bf”
                   Stained Glass 18.1.0 - from the file “Filter Gallery.8bf”
                   Stamp 18.1.0 - from the file “Filter Gallery.8bf”
                   Standard Deviation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
                   STL 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
                   Sumi-e 18.1.0 - from the file “Filter Gallery.8bf”
                   Summation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
                   Targa 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Texturizer 18.1.0 - from the file “Filter Gallery.8bf”
                   Tiles 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Torn Edges 18.1.0 - from the file “Filter Gallery.8bf”
                   Twirl 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   U3D 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
                   Underpainting 18.1.0 - from the file “Filter Gallery.8bf”
                   Vanishing Point 18.1.0 - from the file “VanishingPoint.8bf”
                   Variance 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics.8ba”
                   Virtual Reality Modeling Language | VRML 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
                   Water Paper 18.1.0 - from the file “Filter Gallery.8bf”
                   Watercolor 18.1.0 - from the file “Filter Gallery.8bf”
                   Wave 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Wavefront|OBJ 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D.8bi”
                   WIA Support 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “WIASupport.8li”
                   Wind 18.1.0 - from the file “Standard MultiPlugin.8bf”
                   Wireless Bitmap 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “WBMP.8bi”
                   ZigZag 18.1.0 - from the file “Standard MultiPlugin.8bf”
                Optional and third party plug-ins: NONE
                Duplicate and Disabled plug-ins: NONE
                Plug-ins that failed to load: NONE
                Extensions:
                   com.adobe.inapp.purchase  2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
                   Recent Files  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
                   Libraries  2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
                   New Document  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
                   Start  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
                   com.adobe.experimentation.extension  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
                   Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
                   3D Map Generator - Geo  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\3dmg_GEO.extension\index.html”
                   Export As  3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
                   Device Preview  1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
                   com.adobe.preview.loader  1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
                Installed TWAIN devices: NONE
                • 5. Re: photoshop cc 2017  very slow in startup  :(
                  Hemazone Level 1
                  this is my system info  ,,  i hope it could clear something
                  Touch Bar: Enabled.
                  Highbeam: Enabled.
                  TextComposer: Latin
                  Display: 1
                  AIFOGLInitialized=1
                  OGLContextCreated=1
                  NumGLGPUs=1
                  NumNativeGPUs=0
                  GUIDBucket:
                    bucket: 73
                    test: control
                  Scratch volume(s):
                  Required plug-ins:
                  Extensions:
                  • 6. Re: photoshop cc 2017  very slow in startup  :(
                    I do not see any problem off hand.   There is a newer version CC 2017.1.1  but it look like you have a trial install so I do not know if Adobe updated the to CC 2017.1.1.
                    Try unchecking the show start workspace in you preferences.   See if CC 2017 start any faster then.  Perhaps It stuck doing something on the web.
                    • 7. Re: photoshop cc 2017  very slow in startup  :(
                      Hemazone Level 1
                      SIR ,   as  you can see on of them already was unchecked ,  and the other  checked but i cannot  unchecked it
                      this is fresh version   17.1.1  i installed it few mins ago
                        ,  i didn't installed  3d parties plugins , nor  filters , nor  actions ....etc
                      even i uninstalled it all and delete any files related to photoshop , cleaning my pc with  CCleaner to make sure no any files in registry
                      then reinstall it again   and  still same   ( stuck for more than 40 sec.  on ( scanning for plugins )
                      • 8. Re: photoshop cc 2017  very slow in startup  :(
                        olegl12198859 Level 1
                        Same for me.
                        The latest Photoshop CC 2017 is slow to launch and just slow even on a fast Core i7 machine with 16GB and fast SSD.
                        Very frustrated over my Adobe Photoshop experience.
