• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Renaming a project
Guest
Dec 08, 2008 Dec 08, 2008
hi
I tried to rename my project, i did file | rename project, i changed the project's properties, i changed the project name when generating a layout, etc. and still it seems that i cannot modify the name of the htm file generated... i don't know where i can access the name of the generated htm file so that i can rename it. Can somebody help me?
Thanks a lot
Alex
Views
529
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
First field of the first page of the wizard when you generate the help.
Votes
Translate
Translate
Report
Report
Guest
yeah, i did that.
Votes
Translate
Translate
Report
Report
Community Expert ,
You are saying that if you go to the folder that is defined in that field the name of the start page is not the same as in the wizard?
Votes
Translate
Translate
Report
Report
Guest
I'm saying that on the dialog box called Generate Primary Layout (Flash Help Pro), in the Project Name and Output Folder and Start Page, the information is accurate, it is the right project name, but the name of the htm file generated is not. It is the name of that file that is not generated correctly.
Votes
Translate
Translate
Report
Report
Community Expert ,
OK so the folder defined there is what you want and the help is getting generated there.
- If you are saying that the filename there differs to what gets generated, then I cannot see how that can happen as that is where the name comes from.
- If you are saying the filename in the wizard is not what you want, then simply change it.
Bear in mind this will affect the calls to the help made by your developers so do liaise with them if you change it.
Votes
Translate
Translate
Report
Report
Guest
Jan 07, 2009 Jan 07, 2009
I'm having the same problem: The old name shows up in the browser tab when I run the generated webhelp (htm file).
I ran the File / Rename Project.
Then I changed the Output Start Page on the first page of the wizard when you generate the help.
But when I generate and View Result, the browser tab still has the old name. :(
Edited to add: BTW, I'm generating WebHelp
Votes
Translate
Translate
Report
Report
Guest
poverbo,
It sounds like you're talking about a different thing--rather than the file name, you're trying to change what shows up as the document or page title?
Try going to File > Project Settings in RH and changing the project title. Though if you're using a window defined in the Project Setup pod, the browser title for the help is defined in the window settings instead.
Hope this helps,
Ben
Votes
Translate
Translate
Report
Report
Guest
LATEST
Yep, that was it. I think that's exactly what alexandrafructeam was asking for in this thread.
Thanks!
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
