2 Replies Latest reply on May 4, 2017 4:49 PM by SeanMcCormack
    Change Print Order of Selected Photos
      I have a simple need but cannot seem to find the answer. In a SubFolder of 65 photos I have selected 3 for printing on a sheet with 4 photo locations. I would like the order these 3 photos print. Currently the fill the page 1,2,3,blank - the print order I would like is 3,1,2,blank. Not sure if I have explained this correctly.
      Yeah you are going to ask what version currently 4.4. Have the 5.0 upgrade never installed. This appears to be a basic feature which should have been available since day 0... Thanks Dan
        • 1. Re: Change Print Order of Selected Photos
          WobertC Adobe Community Professional
          If you are using Layout Style of "Single Image/Contact Sheet"  then the photos fill the cells in the sort order on the Filmstrip.
          Easiest way to sort as you want is to make a standard Collection of the photos 1,2,3, and drag them to re-sort as "Custom" 3,1,2. (either in the Filmstrip, or in the Collection) then go to the Print module.
          Note: A "Custom" sort of a folder of photos is not possible if there are any sub-folders.
          Another alternative:  Use the "Custom Package" option in the Print module, define the cells on the page, and drag each photo into any cell placement you want.
          • 2. Re: Change Print Order of Selected Photos
            SeanMcCormack Adobe Community Professional
            wobertc's explanation is great. For automation, using a collection with the images sorted in your prefered order is the most efficient route for Contact Sheet in Print.
