3 Replies Latest reply on May 5, 2017 12:59 AM by Bernd Alheit
    average ignoring empty fields & zero values
    omanbux Level 1
      hi, in my form i want to calculate average in 40 text fields. fields names are AB-1, AB-2, AB-3, etc up to AB-40. i have found bellow code that really works but only issue is that code not ignoring zero values. so can u pls help me edit bellow code to ignore zero. thanks..
      // Initialize variables
      var num = 0;
      var sum = 0;
      // Loop through the input fields
      for (var i = 1; i < 5; i++) {
        var f = getField("AB-" + i);
        if (f.valueAsString) {
        // increment the non-blank field counter
        num++;
        // add the field value to the running total
        sum += +f.value;
      // Calculate the average
      if (num) {
        event.value = sum / num;
      } else {
        // All fields are empty, so set to blank
        event.value = "";
      PDF Form Field calculates AVERAGE incorrectly (PDF Forms)
        • 1. Re: average ignoring empty fields & zero values
          George_Johnson MVP & Adobe Community Professional
          You could change it to something like the following:
          var i, v, num = 0, sum = 0;
          for (i = 1; i <= 40; i++) {
            v = +getField("AB-" + i).value;
            if (v !== 0) {
            // increment the non-blank/zero field counter
            num++;
            sum += +f.value;
          if (num) {
          } else {
            event.value = "";
          • 2. Re: average ignoring empty fields & zero values
            omanbux Level 1
            hi, thanks a lot for your code but answer giving zero & not calculating correctly..
            • 3. Re: average ignoring empty fields & zero values
              Bernd Alheit Adobe Community Professional & MVP
              Use this:
                if (v !== 0) {
                num++;
                sum += v;
              if (num) {
              } else {
                event.value = "";
