13 Replies Latest reply on May 5, 2017 8:19 AM by JJMack
    My brushes keep disappearing in CS6. Any ideas?
    Staffy769541
      Is there a file size limit? I load them up, and can use them and when i shut down PS then reopen it at a later time all that is left is the original dozen or so brushes.. this has happened several times lately and its makin me crazy
      Does anyone have any ideas on this? and also a way to quickly reload all the brushes when this happens.
      thank you..
        • 1. Re: My brushes keep disappearing in CS6. Any ideas?
          It sounds like your Photoshop Preferences may be being reset to Adobe default set. Are you also loosing your loaded actions  and tools preset etc?
          • 2. Re: My brushes keep disappearing in CS6. Any ideas?
            Staffy769541 Level 1
            no im not.. just the brushes... i was wondering if im just overloading them perhaps.. i loaded just 3 large brushes a while back and shut photoshop down after.. then rebooted and opened it back up.. they are still there...
            I use brushes a real  lot and i do load a fair few in..  this is first time this has happened though...
            thanks for the reply..
            • 3. Re: My brushes keep disappearing in CS6. Any ideas?
              Trevor.Dennis Adobe Community Professional (Moderator)
              Adding to what JJ has said, it might help to know what operating system you are using.  There have been some Permission issues with some versions of OSX which might affect Preferences.
              But to clarify, are you saying that you have Appended other brush sets which appear in the brush panel, but are gone after restarting Photoshop?  Or are you referring to new brushes that you have made?
              Reset the brush tool for a start.  In fact reset all tools (left end of Options bar).
              This will help with Permission issues
              http://blogs.adobe.com/crawlspace/2012/07/photoshop-basic-troubleshooting-steps-to-fix-mos t-issues.html
              • 4. Re: My brushes keep disappearing in CS6. Any ideas?
                Do you mean you have loaded a lot of brushes in the presets\brushes folder, or in the brush panel?    I am not sure if there is a limit with the brush panel, but if there is it will be very large.  There is no limit with the brush folder.
                • 5. Re: My brushes keep disappearing in CS6. Any ideas?
                  i load lots of brushes into the brush panel.. Ones i have made and ones i have purchased i cant help myself when it comes to brushes.
                  • 6. Re: My brushes keep disappearing in CS6. Any ideas?
                    im using windows 7 by design..  I had it installed on my new PC.. is that what you mean by OSX not sure what the X means.
                    The brushes that have gone missing have not been recently made.. they are just loaded from ABR files.. im using photoshop CS6
                    although i do have the new photoshop.
                    i will try go and reset all the tools and see if it helps...
                    thank you..
                    • 7. Re: My brushes keep disappearing in CS6. Any ideas?
                      I do not know haw many brushes yon can load in before you reach Photoshop's limit.  I just used the Preset manager to delete all my load brushes. the loaded all the Adobe Brush Presets  that  ship with Photoshop  plus many more brush sets I have one my machine.  I closed down Photoshop and open Photoshop and they are still loaded.   My Use ID Photoshop Brushed file in nearly 49MB rather then its normal 5MB  over 900 brushes are loaded.
                      • 8. Re: My brushes keep disappearing in CS6. Any ideas?
                        I have Windows 10 preview build 16184.1001 installed with over 900 brushed loadednow.  OSX it the operating system that Mac machine use.
                        • 9. Re: My brushes keep disappearing in CS6. Any ideas?
                          • 10. Re: My brushes keep disappearing in CS6. Any ideas?
                            Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967  x64
                            Number of Launches: 274
                            Version: 10 or greater
                            System architecture: Intel CPU Family:6, Model:13, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
                            Physical processor count: 12
                            Logical processor count: 24
                            Processor speed: 1995 MHz
                            Built-in memory: 40886 MB
                            Free memory: 2 MB
                            Memory available to Photoshop: 36955 MB
                            Memory used by Photoshop: 70 %
                            History Thumbnails: Disabled.
                            Touch Bar: Disabled.
                            Alias Layers: Disabled.
                            Modifier Palette: Disabled.
                            Highbeam: Enabled.
                            Image tile size: 1028K
                            Image cache levels: 6
                            Font Preview: Medium
                            TextComposer: Latin
                            Display: 1
                            Display Bounds: top=0, left=0, bottom=1080, right=1920
                            Display: 2
                            Display Bounds: top=0, left=-1360, bottom=768, right=0
                            OpenGL Drawing: Enabled.
                            OpenGL Allow Old GPUs: Not Detected.
                            OpenGL Drawing Mode: Normal
                            OpenGL Allow Normal Mode: True.
                            OpenGL Allow Advanced Mode: False.
                            AIFCoreInitialized=1
                            AIFOGLInitialized=1
                            OGLContextCreated=1
                            NumGLGPUs=1
                            NumCLGPUs=1
                            NumNativeGPUs=0
                            glgpu[0].GLVersion="4.1"
                            glgpu[0].IsIntegratedGLGPU=0
                            glgpu[0].GLMemoryMB=2048
                            glgpu[0].GLName="NVIDIA Quadro 4000"
                            glgpu[0].GLVendor="NVIDIA Corporation"
                            glgpu[0].GLVendorID=4318
                            glgpu[0].GLDriverVersion="21.21.13.7711"
                            glgpu[0].GLRectTextureSize=16384
                            glgpu[0].GLRenderer="Quadro 4000/PCIe/SSE2"
                            glgpu[0].GLRendererID=1757
                            glgpu[0].HasGLNPOTSupport=1
                            glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_78b6 fa1429829a91\nvd3dumx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_7 8b6fa1429829a91\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd 64_78b6fa1429829a91\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf _amd64_78b6fa1429829a91\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi .inf_amd64_78b6fa1429829a91\nvd3dum,C:\WINDOWS\System32\DriverStore\FileRepository\nv_disp wi.inf_amd64_78b6fa1429829a91\nvwgf2um,C:\WINDOWS\System32\DriverStore\FileRepository\nv_d ispwi.inf_amd64_78b6fa1429829a91\nvwgf2um,C:\WINDOWS\System32\DriverStore\FileRepository\n v_dispwi.inf_amd64_78b6fa1429829a91\nvwgf2um"
                            glgpu[0].GLDriverDate="20170317000000.000000-000"
                            glgpu[0].CanCompileProgramGLSL=1
                            glgpu[0].GLFrameBufferOK=1
                            glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
                            glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
                            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                            glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                            glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                            glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                            glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                            glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                            glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                            glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                            clgpu[0].CLPlatformVersion="1.2"
                            clgpu[0].CLDeviceVersion="1.1 CUDA"
                            clgpu[0].IsIntegratedCLGPU=0
                            clgpu[0].CLMemoryMB=2048
                            clgpu[0].CLName="Quadro 4000"
                            clgpu[0].CLVendor="NVIDIA Corporation"
                            clgpu[0].CLVendorID=4318
                            clgpu[0].CLDriverVersion="377.11"
                            clgpu[0].CLBandwidth=7.47626e+10
                            clgpu[0].CLCompute=191.679
                            License Type: Subscription
                            Serial number: 90970090970448917498
                            GUIDBucket:
                              bucket: 235
                              test: DocumentPanel
                            Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
                            Temporary file path: C:\Users\JOHNJM~1\AppData\Local\Temp\
                            Photoshop scratch has async I/O enabled
                            Scratch volume(s):
                              E:\, 3.64T, 3.12T free
                            Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
                            Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
                            Installed components:
                               A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                               ACE.dll   ACE 2017/01/26-01:10:02   79.579975   79.579975
                               AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
                               AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
                               AdobeOwl.dll   Adobe Owl   5.2.11
                               AdobePDFL.dll   PDFL 2016/08/10-16:53:20   79.195992   79.195992
                               AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
                               AdobeSVGAGM.dll   AdobeSVGAGM   79.579975   79.579975
                               AdobeXMP.dll   Adobe XMP Core 2016/09/14-01:09:01   79.159824   79.159824
                               AdobeXMPFiles.dll   Adobe XMP Files 2016/09/14-01:09:01   79.159824   79.159824
                               AdobeXMPScript.dll   Adobe XMP Script 2016/09/14-01:09:01   79.159824   79.159824
                               adobe_caps.dll   Adobe CAPS   10,0,0,6
                               AGM.dll   AGM 2017/01/26-01:10:02   79.579975   79.579975
                               ahclient.dll    AdobeHelp Dynamic Link Library   2.2.0.1
                               AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
                               amtlib.dll   AMTLib (64 Bit)   10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7)   1.000000
                               ARE.dll   ARE 2017/01/26-01:10:02   79.579975   79.579975
                               AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
                               AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                               Bib.dll   BIB 2017/01/26-01:10:02   79.579975   79.579975
                               BIBUtils.dll   BIBUtils 2017/01/26-01:10:02   79.579975   79.579975
                               boost_date_time.dll   photoshopdva   10.0.0
                               boost_signals.dll   photoshopdva   10.0.0
                               boost_system.dll   photoshopdva   10.0.0
                               boost_threads.dll   photoshopdva   10.0.0
                               cg.dll   NVIDIA Cg Runtime   3.0.00007
                               cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                               CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
                               CoolType.dll   CoolType 2017/01/26-01:10:02   79.579975   79.579975
                               dnssd.dll   Bonjour   3,0,0,2
                               dvaaudiodevice.dll   photoshopdva   10.0.0
                               dvacore.dll   photoshopdva   10.0.0
                               dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
                               dvamarshal.dll   photoshopdva   10.0.0
                               dvamediatypes.dll   photoshopdva   10.0.0
                               dvametadata.dll   photoshopdva   10.0.0
                               dvametadataapi.dll   photoshopdva   10.0.0
                               dvametadataui.dll   photoshopdva   10.0.0
                               dvaplayer.dll   photoshopdva   10.0.0
                               dvatransport.dll   photoshopdva   10.0.0
                               dvaui.dll   photoshopdva   10.0.0
                               dvaunittesting.dll   photoshopdva   10.0.0
                               dynamiclink.dll   photoshopdva   10.0.0
                               ExtendScript.dll   ExtendScript 2016/12/13-13:10:33   80.1089815   80.1089815
                               icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                               icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                               icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                               igestep30.dll   IGES Reader   9.3.0.113
                               imslib.dll   IMSLib DLL   10.0.0.11
                               JP2KLib.dll   JP2KLib 2017/04/05-14:24:38   79.266006   79.266006
                               libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                               libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                               libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                               LogSession.dll   LogSession   7.4.1.60.45263
                               mediacoreif.dll   photoshopdva   10.0.0
                               MPS.dll   MPS 2016/09/14-15:20:26   79.577269   79.577269
                               pdfsettings.dll   Adobe PDFSettings   1.04
                               Photoshop.dll   Adobe Photoshop CC 2017   18.1.1
                               Plugin.dll   Adobe Photoshop CC 2017   18.1.1
                               PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   7.0.0
                               PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   7.0.0.67
                               PSArt.dll   Adobe Photoshop CC 2017   18.1.1
                               PSViews.dll   Adobe Photoshop CC 2017   18.1.1
                               SCCore.dll   ScCore 2016/12/13-13:10:33   80.1089815   80.1089815
                               SVGRE.dll   SVGRE   79.579975   79.579975
                               svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                               tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                               tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                               TfFontMgr.dll   FontMgr   9.3.0.113
                               TfKernel.dll   Kernel   9.3.0.113
                               TFKGEOM.dll   Kernel Geom   9.3.0.113
                               TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                               updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
                               VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
                               VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
                               WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
                               wu3d.dll   U3D Writer   9.3.0.113
                            Required plug-ins:
                               3D Studio 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                               Accented Edges 18.1.1 - from the file “Filter Gallery.8bf”
                               Adaptive Wide Angle 18.1.1 - from the file “Adaptive Wide Angle.8bf”
                               Angled Strokes 18.1.1 - from the file “Filter Gallery.8bf”
                               Average 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Average.8bf”
                               Bas Relief 18.1.1 - from the file “Filter Gallery.8bf”
                               BMP 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Camera Raw 9.10 - from the file “Camera Raw.8bi”
                               Camera Raw Filter 9.10 - from the file “Camera Raw.8bi”
                               Chalk && Charcoal 18.1.1 - from the file “Filter Gallery.8bf”
                               Chrome 18.1.1 - from the file “Filter Gallery.8bf”
                               Cineon 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Cineon.8bi”
                               Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds.8bf”
                               Collada 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                               Color Halftone 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Colored Pencil 18.1.1 - from the file “Filter Gallery.8bf”
                               CompuServe GIF 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Conté Crayon 18.1.1 - from the file “Filter Gallery.8bf”
                               Craquelure 18.1.1 - from the file “Filter Gallery.8bf”
                               Crop and Straighten Photos 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “CropPhotosAuto.8li”
                               Crop and Straighten Photos Filter 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Crosshatch 18.1.1 - from the file “Filter Gallery.8bf”
                               Crystallize 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Cutout 18.1.1 - from the file “Filter Gallery.8bf”
                               Dark Strokes 18.1.1 - from the file “Filter Gallery.8bf”
                               De-Interlace 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Dicom 18.1.1 - from the file “Dicom.8bi”
                               Difference Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds.8bf”
                               Diffuse Glow 18.1.1 - from the file “Filter Gallery.8bf”
                               Displace 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Dry Brush 18.1.1 - from the file “Filter Gallery.8bf”
                               Eazel Acquire 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “EazelAcquire.8ba”
                               Entropy 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                               Export Color Lookup Tables 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT.8be”
                               Extrude 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               FastCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “FastCore.8bx”
                               Fibers 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Film Grain 18.1.1 - from the file “Filter Gallery.8bf”
                               Filter Gallery 18.1.1 - from the file “Filter Gallery.8bf”
                               Flash 3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                               Fresco 18.1.1 - from the file “Filter Gallery.8bf”
                               Glass 18.1.1 - from the file “Filter Gallery.8bf”
                               Glowing Edges 18.1.1 - from the file “Filter Gallery.8bf”
                               Google Earth 4 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                               Graphic Pen 18.1.1 - from the file “Filter Gallery.8bf”
                               Halftone Pattern 18.1.1 - from the file “Filter Gallery.8bf”
                               HDRMergeUI 18.1.1 - from the file “HDRMergeUI.8bf”
                               HSB/HSL 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               IFF Format 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               IGES 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                               Ink Outlines 18.1.1 - from the file “Filter Gallery.8bf”
                               JPEG 2000 18.1.1 - from the file “JPEG2000.8bi”
                               Kurtosis 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                               Lens Blur 18.1.1 - from the file “Lens Blur.8bf”
                               Lens Correction 18.1.1 - from the file “Lens Correction.8bf”
                               Lens Flare 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Liquify 18.1.1 - from the file “Liquify.8bf”
                               Matlab Operation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort.8bf”
                               Maximum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                               Mean 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                               Measurement Core 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MeasurementCore.8me”
                               Median 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                               Mezzotint 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Minimum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                               MMXCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MMXCore.8bx”
                               Mosaic Tiles 18.1.1 - from the file “Filter Gallery.8bf”
                               Multiprocessor Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MultiProcessor Support.8bx”
                               Neon Glow 18.1.1 - from the file “Filter Gallery.8bf”
                               Note Paper 18.1.1 - from the file “Filter Gallery.8bf”
                               NTSC Colors 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “NTSC Colors.8bf”
                               Ocean Ripple 18.1.1 - from the file “Filter Gallery.8bf”
                               OpenEXR 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Paint Daubs 18.1.1 - from the file “Filter Gallery.8bf”
                               Palette Knife 18.1.1 - from the file “Filter Gallery.8bf”
                               Patchwork 18.1.1 - from the file “Filter Gallery.8bf”
                               Paths to Illustrator 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               PCX 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PCX.8bi”
                               Photocopy 18.1.1 - from the file “Filter Gallery.8bf”
                               Photoshop 3D Engine 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Photoshop3DEngine.8bi”
                               Photoshop Touch 14.0 - from the file “PSDX.8bi”
                               Picture Package Filter 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort.8bf”
                               Pinch 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Pixar 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Pixar.8bi”
                               Plaster 18.1.1 - from the file “Filter Gallery.8bf”
                               Plastic Wrap 18.1.1 - from the file “Filter Gallery.8bf”
                               PLY 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                               PNG 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Pointillize 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Polar Coordinates 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Portable Bit Map 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PBM.8bi”
                               Poster Edges 18.1.1 - from the file “Filter Gallery.8bf”
                               PRC 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                               Radial Blur 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Radiance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Radiance.8bi”
                               Range 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                               Render Color Lookup Grid 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT.8be”
                               Reticulation 18.1.1 - from the file “Filter Gallery.8bf”
                               Ripple 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Rough Pastels 18.1.1 - from the file “Filter Gallery.8bf”
                               Save for Web 18.1.1 - from the file “Save for Web.8be”
                               ScriptingSupport 18.1.1 - from the file “ScriptingSupport.8li”
                               Shake Reduction 18.1.1 - from the file “Shake Reduction.8bf”
                               Shear 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Skewness 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                               Smart Blur 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Smudge Stick 18.1.1 - from the file “Filter Gallery.8bf”
                               Solarize 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Solarize.8bf”
                               Spaces 18.1.1 - from the file “Spaces.8li”
                               Spatter 18.1.1 - from the file “Filter Gallery.8bf”
                               Spherize 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Sponge 18.1.1 - from the file “Filter Gallery.8bf”
                               Sprayed Strokes 18.1.1 - from the file “Filter Gallery.8bf”
                               Stained Glass 18.1.1 - from the file “Filter Gallery.8bf”
                               Stamp 18.1.1 - from the file “Filter Gallery.8bf”
                               Standard Deviation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                               STL 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                               Sumi-e 18.1.1 - from the file “Filter Gallery.8bf”
                               Summation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                               Targa 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Texturizer 18.1.1 - from the file “Filter Gallery.8bf”
                               Tiles 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Torn Edges 18.1.1 - from the file “Filter Gallery.8bf”
                               Twirl 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               U3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                               Underpainting 18.1.1 - from the file “Filter Gallery.8bf”
                               Vanishing Point 18.1.1 - from the file “VanishingPoint.8bf”
                               Variance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                               Virtual Reality Modeling Language | VRML 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                               Water Paper 18.1.1 - from the file “Filter Gallery.8bf”
                               Watercolor 18.1.1 - from the file “Filter Gallery.8bf”
                               Wave 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Wavefront|OBJ 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                               WIA Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WIASupport.8li”
                               Wind 18.1.1 - from the file “Standard MultiPlugin.8bf”
                               Wireless Bitmap 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WBMP.8bi”
                               ZigZag 18.1.1 - from the file “Standard MultiPlugin.8bf”
                            Optional and third party plug-ins:
                               Analog Efex Pro 2 2.0.12.12 - from the file “C:\Program Files\Google\Nik Collection\Analog Efex Pro 2\Analog Efex Pro 2 (64-Bit)\Analog Efex Pro 2.8bf”
                               BackgroundFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Background.8bf”
                               Color Efex Pro 4 4.3.24.12 - from the file “C:\Program Files\Google\Nik Collection\Color Efex Pro 4\Color Efex Pro 4 (64-Bit)\Color Efex Pro 4.8bf”
                               CUR (Windows Cursor) NO VERSION - from the file “C:\Photoshop64 Plug-Ins\icon format\ICOFormat64.8bi”
                               Dfine 2 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Dfine2.8bf”
                               Face Control II 2.00 - from the file “C:\Photoshop64 Plug-Ins\Redfield\FaceControl(X64).8bf”
                               Fine Touch 3.25 - from the file “C:\Photoshop64 Plug-Ins\Redfield\FineTouch(X64).8bf”
                               FineStructuresFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\FineStructures.8bf”
                               GREYCstoration NO VERSION - from the file “C:\Photoshop64 Plug-Ins\GreycShop_x64_LAA_2013-08-04\Greyc-x64.8bf”
                               HDR Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2 (64-Bit)\HDR Efex Pro 2.8bf”
                               HotPixelsFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\HotPixels.8bf”
                               ICO Windows Icon/Favicon NO VERSION - from the file “C:\Photoshop64 Plug-Ins\icon format\ICOFormat64.8bi”
                               Import from FastPictureViewer Codec Pack 3.8.0.96 - from the file “C:\Photoshop64 Plug-Ins\FastPictureViewerCodecPack\FastPictureViewerCodecPack.PhotoshopImport64.8ba”
                               JPEG XR 1, 1, 0, 0 - from the file “C:\Photoshop64 Plug-Ins\Microsoft\JPEGXR_x64.8bi”
                               Lazy Nezumi Pro 17.3.25.1950 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\MouseHookPro64.8li”
                               Luce NO VERSION - from the file “C:\Photoshop64 Plug-Ins\Luce2_64\luce_64.8bf”
                               Merge to HDR Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2 (64-Bit)\HDR Efex Pro 2.8bf”
                               Nik Collection Selective Tool 2.1.28 - from the file “C:\Photoshop64 Plug-Ins\Google\Selective Tool\SelectivePalette.8li”
                               Reduce Noise v8 8.0.1.0 - from the file “C:\Photoshop64 Plug-Ins\NeatImage8\NeatImage8.8bf”
                               ScriptListener 13.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\ScriptListener.8li”
                               SGI RGB 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) - from the file “C:\Photoshop64 Plug-Ins\SGIRGB\SGIRGB.8BI”
                               ShadowsFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Shadows.8bf”
                               Sharpener Pro 3: (1) RAW Presharpener 3.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Sharpener Pro 3\Sharpener Pro 3 (64-Bit)\SHP3RPS.8bf”
                               Sharpener Pro 3: (2) Output Sharpener 3.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Sharpener Pro 3\Sharpener Pro 3 (64-Bit)\SHP3OS.8bf”
                               Silver Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\Silver Efex Pro 2\Silver Efex Pro 2 (64-Bit)\Silver Efex Pro 2.8bf”
                               SkinFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Skin.8bf”
                               SkyFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Sky.8bf”
                               StarFilter Pro 3 3.0.5.1 - from the file “C:\Photoshop64 Plug-Ins\ProDigitalSoftware\StarFilterPro3X64.8bf”
                               StrongNoiseFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\StrongNoise.8bf”
                               SuperPNG 2.0 - from the file “C:\Photoshop64 Plug-Ins\SuperPNG\SuperPNG.8bi”
                               Viveza 2 2.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Viveza 2\Viveza 2 (64-Bit)\Viveza2.8bf”
                            Duplicate and Disabled plug-ins: NONE
                            Plug-ins that failed to load: NONE
                            Extensions:
                               Recent Files  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
                               com.adobe.inapp.purchase  2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
                               Libraries  2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
                               Start  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
                               Export As  3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
                               com.adobe.preview.loader  1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
                               New Document  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
                               com.adobe.experimentation.extension  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
                               Adobe Color Themes  6.1.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\KulerPanelHTMLBundle\index.html”
                               Device Preview  1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
                               JSX Launcher  0.1.4 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\net.sytes.chuwa.jsxlauncher\index.html”
                            Installed TWAIN devices: NONE
                            • 11. Re: My brushes keep disappearing in CS6. Any ideas?
                              some of the new brushes i have purchased are all around the 5000 pixels each... i dont need them that large.. just looked the abr file is 431mb maybe thats my problem... thats just 1 abr file.. the second one is 100mb...
                              wow !!!
                              • 12. Re: My brushes keep disappearing in CS6. Any ideas?
                                wow i have no idea where you found all that photoshop details i do know where my windows are...
                                • 13. Re: My brushes keep disappearing in CS6. Any ideas?
                                  Your Adobe Photoshop System info is in Photoshop menu Help>System Info.....
