auntiealias
> I tried that, but as far as I could figure you still
have to have a specific column name
Look at the udf more closely. If you read the documentation
it states all of the parameters are optional, except the query. So
if you do not supply column names, the function will use the
columnList variable to determine the names of the columns in the
query. If you look at the actual code, notice it uses array
notation to extract the values (not evaluate) .
... (code to create query) ...
<!--- pass in the query object only ---->
<cfset test = QueryToCSV2( data )>
http://cflib.org/index.cfm?event=page.udfbyid&udfid=1197
> I have a cfselect with multiple set to "yes" and the
selections are "which columns of
> data do you want to see?"
Hopefully you are not using the raw form value directly in
your sql, because that is a sql injection attack just waiting to
happen.
