• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Photoshop hangs when opening a video
Community Beginner ,
May 05, 2017 May 05, 2017
Hi, has anybody faced this issue of not being able to open a mp4 video in photoshop? It seems to be progressing all the way right up to the end where it says reading video format and shows the progress wheel, but nothing happens.
I have been able to read mp4s as soon as 2 days ago, no issues, but suddenly today this happens.
I can open the video file using media player, and there's no issue either.
Where is the first place I should look/ or first thing I could do to try to troubleshoot this?
Thanks!
Views
1.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , May 07, 2017 May 07, 2017
Yes, that was the next step I was going to try - uninstalling and reinstalling Photoshop.
It works now.
Thanks!
Votes
Translate
Translate
Adobe
Community Expert ,
Does the file play OK in Media Player or VLC?
Have you tried opening one of the older MP4 files that you know used to load OK?
If that doesn't work either, reset Preferences.
If the old file loads then run the problem file through Handbrake.  No need to convert.  Just go from MP4 to MP4.
https://handbrake.fr/
BTW  Video professionals all over the world use Handbrake.  It's a little bit of magic that reduces file size with no discernible impact on quality.
Votes
Translate
Translate
Report
Report
May 06, 2017 May 06, 2017
Yes, it plays fine in Media Player.
I just tried following and all don't work:
-      opening the older mp4 file
-      reset preferences
-      run file through handbrake
Thanks for trying anyway, but any other suggestions?
Votes
Translate
Translate
Report
Report
Community Expert ,
And did it load OK?
You realise that the steps I gave you were conditional?  If an MP4 file that previously loaded and played in the timeline now doesn't, then you know Photoshop is broken.  There's no point in running the newer file through Handbrake, because you have just discovered that Photoshop is broken.  Right?
Resetting Preferences was worth a try, but if that made no difference, then time to get serious, and reinstall Photoshop.  That will reload all the video CODECs again, and if the file plays OK in Media Player, I would expect it to then load and play in Photoshop.
Good luck.
Votes
Translate
Translate
Report
Report
LATEST
It works now.
Thanks!
Votes
Translate
Translate
Report
Report
