• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Photoshop tools reset on every click since new update
New Here ,
May 07, 2017 May 07, 2017
Example:
- Shift+B-Keys to switch from brush to pen (since I do pixel art)
- V-Key to move layer, or L for the lasse
- B-Key to go back to the pen reloads the initial brush!
Same for polyfon lasso vs standard lasso, gradient vs bucket etc and all other tools.
It never returns to what you were just using, but always to some sort of factory default.
What I have done:
- Followed the instructions from someone with the same bug a while back (Tools keep resetting after update last night )
- Reset Photoshop settings (shift/ctrl/alt) on start-up
- Reset all tools
Nothing solved the problem.
Photoshop is no longer usable under these circumstances. A workaround is urgent, thanks.
Views
1.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , May 07, 2017 May 07, 2017
When you say Pen, do you mean Pencil?  Or have you change the Pen Tool shortcut to B?
I'm wondering if Use Shift Key for Tool Switch has been turned off and hitting the B key toggles between Brush and Pencil?  What that might result in is you switching to the other tool and whatever brush it was set to use.
Anyway, steps to take in order are
Reset All tools
And if still stuck, Reset Preferences.
If that doesn't fix it look at this Trouble Shooting guide and specifically Permissions.
http://blogs.adobe.com/crawlspace/2012/07/photoshop-basic-troubleshooting-steps-to-fix-most-issues.html
Votes
Translate
Translate
Adobe
Community Expert ,
What version of photoshop and operating system are you using?
You can find the exact photoshop version by going to Help>System Info in photoshop and reading the top line.
Votes
Translate
Translate
Report
Report
New Here ,
I'm running PS on a Windows 10 machine.
System Info returns the following (copied the first few lines):
Adobe Photoshop Version: 2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877  x64
Number of Launches: 1
Version: 10 or greater
System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 2394 MHz
Built-in memory: 12205 MB
Free memory: 5542 MB
Memory available to Photoshop: 10687 MB
Memory used by Photoshop: 70 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Enabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi
That is not the latest update. Latest version is 2017.1.1 r252.
I would try updating.
Dave
Votes
Translate
Translate
Report
Report
Community Expert ,
Reset All tools
http://blogs.adobe.com/crawlspace/2012/07/photoshop-basic-troubleshooting-steps-to-fix-most-issues.h...
It would help if we knew what operating system you are using.
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Many thanks for your kind help.
I'm not sure what solved it, but I updated again (now sys info shows Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967  x64), plus did the changes you mentioned, and behaviour is now as expected.
I can carry on working now, thank you very much.
Votes
Translate
Translate
Report
Report
