• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
specs for full hd/4k playout and full hd/4k streaming
Guest
May 07, 2017 May 07, 2017
Need to get a few new computers (streaming desktop, streaming laptop, playout laptop)
wondering about how to spec them out
What is the requirement for playing full HD to an LED wall for example?  and also what is needed to play 4K videos to LED wall.
And what is needed only for full HD streaming?
and for 4K streaming what specs on a system are needed?
thank you sooo much
Views
500
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
I've moved this to the Hardware Forum where the hardware experts hang out.
Votes
Translate
Translate
Report
Report
LEGEND ,
I guess the only difference between playout and streaming would be the playout on your laptop would be that it requires a builtr-in 4K monitor, a streaming device device is connected  to drive your wall display and does not necessarily have its own high resolution display.
Is that correct?  This "hardware" forum we really deal with the much, much more demanding problem of configuring editing computers
Votes
Translate
Translate
Report
Report
Guest
May 08, 2017 May 08, 2017
Great, thank you.
For an HD playout we were looking for a system with i7 - 7th generation processor that turbos up to 3.5GHz at least, 16GB Ram, and full HD capale graphics card (possible Quadro M2200).
Is this enough for nicely playing HD videos onto LED wall?  Any other suggestions for this type of laptop?
And if we want to play 4K onto LED wall what kind of system specs do we need?
Then for full HD streaming we were looking at a CPU i7 - 7th Gen. turbo up to 3.9GHz (will stream with overlays), 32GB Ram and Quadro M2200 4GB GPU.
Would this be sufficient?
What kind of specs would we want for 4K streaming?
We have done some testing and found we need higher specifications than what was expected to achieve the streaming rates we wanted so I wanted anyone to share their experience of what specs for systems will do these things.
Thank you
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
I do not know if any laptops are equipped with these new Pascal based Quadros , but they are a world difference You might check with one of the custom laptop builder like XoticPC.  Of course it is definitely easier to get a Pascal based GeForce GTX 10xx series.  Notice on the Quadro chart these new Pascal based mobile GPU's have twice the memory bandwidth and also a newer DisplayPort 1.4 specification which is also true of the GTX 10xx series
"DisplayPort 1.4 can support 8K UHD (7680×4320) at 60 Hz with 30 bit/px RGB color and HDR, or 4K UHD (3840×2160) at 120 Hz with 30 bit/px RGB color and HDR. 4K at 60 Hz with 30 bit/px RGB color and HDR"
What is your "wall" display input interface/specification?
Votes
Translate
Translate
Report
Report
