8 Replies Latest reply on May 8, 2017 2:34 AM by SuperMerlin
    JavaScripting HSB
    andrea1173782
      Still new to all this.
      I'm making script, and as a step I need to shift hue by set amount in recently opened document.
      Like this:
      Before, just opened
      After hue shift +80
      I tried to google it, but everything listed doesn't work for me. Currently I just use bit recorded with ScriptListener:
          var idHStr = charIDToTypeID("HStr");
          var desc5 = new ActionDescriptor();
          var idpresetKind = stringIDToTypeID("presetKind");
          var idpresetKindType = stringIDToTypeID("presetKindType");
          var idpresetKindCustom = stringIDToTypeID("presetKindCustom");
          desc5.putEnumerated(idpresetKind, idpresetKindType, idpresetKindCustom);
          var idClrz = charIDToTypeID("Clrz");
          desc5.putBoolean(idClrz, false);
          var idAdjs = charIDToTypeID("Adjs");
          var list1 = new ActionList();
          var desc6 = new ActionDescriptor();
          var idH = charIDToTypeID("H   ");
          desc6.putInteger(idH, 80);
          var idStrt = charIDToTypeID("Strt");
          desc6.putInteger(idStrt, 0);
          var idLght = charIDToTypeID("Lght");
          desc6.putInteger(idLght, 0);
          var idHsttwo = charIDToTypeID("Hst2");
          list1.putObject(idHsttwo, desc6);
          desc5.putList(idAdjs, list1);
          executeAction(idHStr, desc5, DialogModes.NO);
      But that's too crude and hard to manage.
      I know, that I must set SolidColor, like this:
      var NewHue = new SolidColor();
      NewHue.hsb.hue = 80;
      But I cannot apply it. Well, app says I applied it, but no difference seen.
        • 1. Re: JavaScripting HSB
          pixxxel schubser MVP & Adobe Community Professional
          Your ScriptListener code works as it is (on every selected artlayer). This means the layer should be selected (and not a layer with a selection). And you don't need a new SolidColor.
          Save you code as jsx and run from script menu in PS.
          Here is the same code as yours, but only a little bit cleaned
          var desc1 = new ActionDescriptor();
          desc1.putEnumerated( stringIDToTypeID('presetKind'), stringIDToTypeID('presetKindType'), stringIDToTypeID('presetKindCustom') );
          desc1.putBoolean( charIDToTypeID('Clrz'), false );
                  var desc2 = new ActionDescriptor();
                  desc2.putInteger( charIDToTypeID('H   '), 80 );
                  desc2.putInteger( charIDToTypeID('Strt'), 0 );
                  desc2.putInteger( charIDToTypeID('Lght'), 0 );
              list1.putObject( charIDToTypeID('Hst2'), desc2 );
          desc1.putList( charIDToTypeID('Adjs'), list1 );
          executeAction( charIDToTypeID('HStr'), desc1, DialogModes.NO );
          Have fun
          • 2. Re: JavaScripting HSB
            SuperMerlin Level 5
            Try this...
            hueLayer(80,0,0);
            function hueLayer(hue,sat,bright) {
            var desc86 = new ActionDescriptor();
            var ref51 = new ActionReference();
            ref51.putClass( charIDToTypeID('AdjL') );
            desc86.putReference( charIDToTypeID('null'), ref51 );
            var desc87 = new ActionDescriptor();
            var desc88 = new ActionDescriptor();
            desc88.putEnumerated( stringIDToTypeID('presetKind'), stringIDToTypeID('presetKindType'), stringIDToTypeID('presetKindDefault') );
            desc88.putBoolean( charIDToTypeID('Clrz'), false );
            desc87.putObject( charIDToTypeID('Type'), charIDToTypeID('HStr'), desc88 );
            desc86.putObject( charIDToTypeID('Usng'), charIDToTypeID('AdjL'), desc87 );
            try{
            executeAction( charIDToTypeID('Mk  '), desc86, DialogModes.NO );
            }catch(e){}
            var desc89 = new ActionDescriptor();
            var ref52 = new ActionReference();
            ref52.putEnumerated( charIDToTypeID('Chnl'), charIDToTypeID('Chnl'), charIDToTypeID('RGB ') );
            desc89.putReference( charIDToTypeID('null'), ref52 );
            desc89.putBoolean( charIDToTypeID('MkVs'), false );
            try{
            executeAction( charIDToTypeID('slct'), desc89, DialogModes.NO );
            }catch(e){}
            var desc90 = new ActionDescriptor();
            var ref53 = new ActionReference();
            ref53.putEnumerated( charIDToTypeID('AdjL'), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
            desc90.putReference( charIDToTypeID('null'), ref53 );
            var desc91 = new ActionDescriptor();
            desc91.putEnumerated( stringIDToTypeID('presetKind'), stringIDToTypeID('presetKindType'), stringIDToTypeID('presetKindCustom') );
            var list9 = new ActionList();
            var desc92 = new ActionDescriptor();
            desc92.putInteger( charIDToTypeID('H   '), hue );
            desc92.putInteger( charIDToTypeID('Strt'), sat );
            desc92.putInteger( charIDToTypeID('Lght'), bright );
            list9.putObject( charIDToTypeID('Hst2'), desc92 );
            desc91.putList( charIDToTypeID('Adjs'), list9 );
            desc90.putObject( charIDToTypeID('T   '), charIDToTypeID('HStr'), desc91 );
            try{
            executeAction( charIDToTypeID('setd'), desc90, DialogModes.NO );
            }catch(e){}
            • 3. Re: JavaScripting HSB
              andrea1173782 Level 1
              I know that it works, script containing it worked just fine.
              Now I have to include it in more elaborate algorhitm than before, and this block is very hard to properly maintain.
              I hoped that there exists something shorter and more transparent, about 5-6 lines total.
              • 4. Re: JavaScripting HSB
                How good is your Javascript knowledgebase?
                You can work with functions. Rewrite the above code as function
                function hueCorrection(hue, sat, bright) {
                            desc2.putInteger( charIDToTypeID('H   '), hue );
                            desc2.putInteger( charIDToTypeID('Strt'), sat );
                            desc2.putInteger( charIDToTypeID('Lght'), bright );
                Call this function with this line whenever you need it:
                hueCorrection(80,0,0);
                Have fun
                • 5. Re: JavaScripting HSB
                  Well, little to none, see above.
                  • 6. Re: JavaScripting HSB
                    Without to write two lines in one it seems to be that 8 lines are the minimum required code
                    (desc1 = new ActionDescriptor()).putEnumerated(stringIDToTypeID('presetKind'), stringIDToTypeID('presetKindType'), stringIDToTypeID('presetKindCustom'))
                    desc1.putBoolean(stringIDToTypeID('colorize'), false);
                    (desc2 = new ActionDescriptor()).putInteger(stringIDToTypeID('hue'), 80)
                    desc2.putInteger(stringIDToTypeID('saturation'), 0)
                    desc2.putInteger(stringIDToTypeID('lightness'), 0);
                    (list1 = new ActionList()).putObject(stringIDToTypeID('hueSatAdjustmentV2'), desc2);
                    desc1.putList(stringIDToTypeID('adjustment'), list1)
                    executeAction(stringIDToTypeID('hueSaturation'), desc1, DialogModes.NO);
                    • 7. Re: JavaScripting HSB
                      So, that hsb property in ref table is just for show?
                      • 8. Re: JavaScripting HSB
                        SuperMerlin Level 5
                        No it is not just for show.
                        You can use it to set the foreground/background colour or a single pixel colour.
                        You can not use it for an adjustment layer, action manager code is required to do that.
