1. Re: Problem With Converting The Image
dj_paige May 7, 2017 11:26 AM (in response to El`FAngle)1 person found this helpfulOne possibility is that one (or both) of your computer monitors is not properly calibrated. Make sure that the monitors are properly calibrated.
You didn't say what steps you followed to perform this transfer to another computer. Could you please provide that in detail? In particular, are you exporting the photo from Lightroom on the Mac, or not. As I said, we need to know all the details.
2. Re: Problem With Converting The Image
El`FAngle May 7, 2017 11:37 AM (in response to El`FAngle)i did export the image from lightroom. from RAW to JPEG ,
then after exporting it , i copy the image to my pendrive.
then i open it at window.
but it still shown over exposes.
if i have to calibrated the monitors , how do can i do it ? need some explaination on it , im just using my macbook air.
3. Re: Problem With Converting The Image
dj_paige May 7, 2017 12:03 PM (in response to El`FAngle)1 person found this helpfulI don't know how to calibrate a monitor on a Mac, but I'm sure your favorite search engine can find the instructions.
Why don't you just send the RAW and it's associated XMP file over to the Windows computer?
4. Re: Problem With Converting The Image
El`FAngle May 7, 2017 12:09 PM (in response to El`FAngle)its is posible the lightroom save the image by RAW ?? i can see the option for export is
JPEG
PSD
TIFF
DNG
ORIGINAL
CAN U GUIDE ME IF U DONT MIND ?? HMM
5. Re: Problem With Converting The Image
dj_paige May 7, 2017 12:45 PM (in response to El`FAngle)1 person found this helpful"Save"? I didn't say anything about "save" because Lightroom doesn't do a save. You also don't export the photo.
If you want to transfer a RAW from your MAC to your PC, you simply copy the RAW and corresponding XMP file using Mac Finder and send it to the PC. Then you can import it into your catalog on the PC.
Even better, you can select the files in LR on your Mac, export the catalog (File->Export as Catalog), make sure that Export Selected Photos and Export Negative Files are checked, give a name to the exported catalog; and move everything to the PC and the in the PC version of LR select File->Import from Another Catalog. -
6. Re: Problem With Converting The Image
El`FAngle May 7, 2017 12:55 PM (in response to dj_paige)okay , i can export it .
but if i "export the catalog" do my client able to view the picture from PC if they do not have the lightroom apps ??
because now the things is , i got problem when i wanna give my pictures to the client, they open it using Window , and the picture is over exposes.
so conclusion is , i wanna give the picture to my client without any problem of the images.
7. Re: Problem With Converting The Image
dj_paige May 7, 2017 2:23 PM (in response to El`FAngle)1 person found this helpfulOkay, the situation where the client does not have Lightroom has not been mentioned before, and so in that case, you must export the photo as JPG (or TIF) using sRGB as the Color Space when you export. Having a calibrated monitor at both ends of this process will help. If your customer is not using a properly color managed application to view the images, then the colors can be off, and the brightness can be off if the customer's monitor is set too bright or too dark.
